IPD sale Volvo Parts
XeMODeX - Experts in Volvo Electronics My Swedish Parts ad - genuine Volvo parts
Did you know? 🤔
LED code reader/ECC help
Sommerfeldt
Year and Model: 1996 850 T5
Has thanked: 49 times
Been thanked: 29 times
Norway
Sommerfeldt
Re: LED code reader/ECC help
Post by Sommerfeldt » Mon May 06, 2019 6:09 am
0261203628 is a US spec 850 R with M4.3. No doubt about it.
As to your actual issue, it kind of sounds like you're using the wrong pins... if you switch the two "grounds", you'll have a steady light and no function. Put the + in 16, one ground in 5 and the other in the pin for the module you want to read. There should be a steady light. Put car in ON - light should go out, and you can use the momentary switch for 1 second. Should be light while the switch is pressed, then go out for ~2-5 seconds, then code readout.
- S
'96 855 T5, R bumper and spoiler, Koni Yellows & blue H&R springs all 'round.
Peevarino
Year and Model: 2009 XC70, 97 855R
Has thanked: 10 times
Been thanked: 0
United States of America
Peevarino
Post by Peevarino » Mon May 06, 2019 6:23 am
I figured it was 4.3. Wouldn’t have been upset if I was wrong.
I’ll give it another go, I wanted to work on it this weekend, ended up rebuilding a leaky oil cooler line instead. Probably less contorting than climate control work, though.
09 XC70 3.2
97 855R
Chuck W
Year and Model: 97 854 T5
Has thanked: 9 times
Been thanked: 14 times
Chuck W
Post by Chuck W » Mon May 06, 2019 7:00 am
RickHaleParker wrote:
Sun May 05, 2019 4:41 pm
Peevarino wrote:
Sun May 05, 2019 8:06 am
I posted in here because it’s for a 97 850, not the 09 I have listed in my profile.
Motronic 4.4 started showing up in some '96 850s.
"97 is pretty much the year they moved to Motronic 4.4.
The LED code readers work for reading ECC codes on the '97 850's. It doesn't care whether the ECU is 4.3 or 4.4.
OP, make sure you're connected to the proper pins. The pic in the linked post shows a connection for reading ECU codes (#3), and not ECC codes (#6). I used a 1K Ohm resistor in my set-up and have used in on my '96GLT, '97GLT, and '97T5.
Peevarino
Been thanked: 0
Peevarino
Post by Peevarino » Tue May 07, 2019 6:14 pm
I’m going with the resistor is the issue, double and triple checked I had the right pins.
Time to order some resistors.
Once that’s sorted out, I’m assuming this set up would work fine for abs codes, too? I realized last night my abs/tracs lights don’t light up on the dash.
09 XC70 3.2
97 855R
RickHaleParker
Has thanked: 3 times
Been thanked: 312 times
RickHaleParker
Post by RickHaleParker » Tue May 07, 2019 7:30 pm
The LED doesn't care but some of the 4.4 have the flash code routine some do not.
He would be better off with a ELM327 and 850 OBD-II. Which was developed for the Volvo 850.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Chuck W
Chuck W
Post by Chuck W » Tue May 07, 2019 7:42 pm
For engine codes, sure, but for his ECC codes, the LED should be sufficient. I use an BT ELM327 unit for engine codes on the cars.
Peevarino
Been thanked: 0
Peevarino
Post by Peevarino » Tue May 07, 2019 7:52 pm
Would help if I had an Android device...
I’ll be sticking with the blinky thing for now. Well, once I get it blinking
09 XC70 3.2
97 855R
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue May 07, 2019 7:58 pm
Got a Windows PC or a Mac? 850 OBD-II will run under the free Android emulator NOX Player.
Sommerfeldt
Norway
Sommerfeldt
Post by Sommerfeldt » Tue May 07, 2019 10:25 pm
I for one couldn’t get that app to do diddly squat. Wouldn’t even connect to anything, let alone tell me something useful. So I’m also using my trusty blinky tool.
- S
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue May 07, 2019 10:34 pm
The BT connect can be touchy. Aleksi Venäläinen has been notified, he going to work on that. Even with that short coming, I find it less work then counting flashes.
