Did you know? 🤔
LED code reader/ECC help
misha
Has thanked: 56 times
Been thanked: 134 times
Serbia
misha
Re: LED code reader/ECC help
Post by misha » Thu May 09, 2019 4:36 pm
Last year 850s with M4.4 still use flash codes for ECC ONLY.
Everything is fully OBD II except ECC.
So...flash code reader will work on ECC.
S,v70 from '97 (transitional year from 850 to S,V70)got fully OBDII ECC and Volvo Scan tool is required for diagnostics.
These users thanked the author misha for the post:
Peevarino
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
Has thanked: 3 times
Been thanked: 539 times
United States of America
RickHaleParker
Post by RickHaleParker » Fri May 10, 2019 12:00 am
I know on the 960/S90/V90 with 4.3, 4.4, the ECC has a built in flash code reader for the ECC only.
Has anybody ever tried this on the 850 ECC?
SELF-DIAGNOSTIC SYSTEM
The EEC system incorporates a self-diagnostic function that indicates system faults through a series of trouble codes. The presence of fault(s) is indicated by flashing A/C OFF button. The control panel is programmed to enter a pre-programmed mode when a fault is detected. Under fault condition, control panel ignores the faulty signal, selects an alternative pre-programmed value and prevents delivery of faulty output signals.
Entering Self-Diagnostics
To enter mode, ensure engine is running. Shine a non-fluorescent, bright light on solar sensor. Place blower fan control knob in AUT position and function selector knob in vent position.
1. Place temperature control knob to maximum cooling (pointing straight down).
2. Ensure recirculated air switch is depressed and A/C OFF button is released.
3. Depress and release A/C OFF button within 5 seconds to start self-diagnostic mode.
Each fault code consists of 3 digits. For example, Code132 is displayed by a single flash of the A/C OFF button for the first digit (number 1). After a pause, the second digit of code (number 3) is indicated by 3 flashes. After another pause, the third digit of code (number 2) is indicated by 2 flashes. See TROUBLE CODE IDENTIFICATION table.
Three different fault codes may be stored in memory. However, only one code may be displayed upon request. It may be necessary to request display of fault codes a number of times to ensure all fault codes are displayed.
Exiting Self-Diagnostics & Clearing Codes
To exit self-diagnostics, turn ignition off. All codes are cleared when ignition is turned off. Fault codes are not stored in memory. Even if a code has occurred several times during a period of time, code will only be stored until ignition is turned off.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
Peevarino
Year and Model: 2009 XC70, 97 855R
Has thanked: 28 times
Been thanked: 3 times
Peevarino
Post by Peevarino » Fri May 10, 2019 4:02 am
That sounds interesting, but where’s the solar sensor?
09 XC70 3.2
97 855R
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri May 10, 2019 4:52 am
The solar sensor, combined with the theft alarm diode, is a photodiode which generates a current when exposed to solar radiation. In other words the blinking led on the top of the dash.
A led can be use as a light source or a light detector. When the anti-theif is armed it is used as a light. When the anti-theif is disarmed, it is used as a light detector.
This is how the Driver Information Module (DIM) knows when to automatically dim the dash lights.
Peevarino
Peevarino
Post by Peevarino » Fri May 10, 2019 5:11 am
I’ll give it a go when I get to work today
09 XC70 3.2
97 855R
Has thanked: 316 times
Been thanked: 979 times
Trinidad & Tobago
Post by abscate » Fri May 10, 2019 7:27 am
Doesn't this same sensor also serve as an input into ECC for solar heat load?
I didn't know they dual purposed the LED - thats clever.
Link To Volvo Glossary
misha
Serbia
misha
Post by misha » Fri May 10, 2019 8:58 am
No...no LED.
There is LED and solar sensor on that piece of plastic.
Led for Volvo Guard II on the top of it and solar sensor for ECC aside.
It's NOT for dimming the dash lights...at least on 850.
I have it...bought the car almost brand new and don't have that feature.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri May 10, 2019 5:04 pm
"In direct sunlight, the temperature control dampers are positioned to provide a lower temperature, as determined by solar
sensor input. If the engine is cold and outside temperature is low, the temperature control dampers are set for more heat to reach the
desired temperature faster."
LEDs have been used to build Poorman's Pyranometers.
