Hot amrrest, transmission issue ?
Dynamic D
Year and Model: v70 2006
Post by Dynamic D »
Hello,
I have a Volvo 2006 with 200 000 km on it. Yesterday, I noticed that my arm rest (where I put the CD) was hot. I let the car cool down all night and today I looked if the transmission fluid was ok. The level is ok, and the color is kind of red/brownish. I took the car again and when I got home, again, the armrest was hot again. What could be the cause of that ? I thought about the transmission because that is what goes underneath the armrest, but it could be something else...
Thanks for your help
Dynamic D
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The transmission doesn't go there, below that area is the catalytic converter. May put the car on a a lift (don't go underneath only with the spare jack), and look first if the car still has the aluminum heat shield at the top of the exhaust tunnel (above the exhaust pipe). If this heat shield appears to be in good condition, run the car at night and see if the catalytic converter glows red even only slightly. You can see in this video how these heat shields look like, those U shaped pieces of aluminum like sheets with a 'dot' pattern on them, mine were a little bent www.youtube.com/watch?v=UPXHAH3vAVM
Dynamic D
Post by Dynamic D »
Ok thanks oragex.
So that seems to be good news. I will look tonight if the heat shield is there.. if it is not, is it something that could be dangerous for other parts of the car ? Because if it is just a bit of heat on the arm rest, I think I could live with that...
Dynamic D
oragex
Post by oragex »
I don't think that would be a problem, I think the fuel lines are not close, the handbrake lines are in the area, don't think it would be too hot to damage them. However a glowing catalytic converter usually means either running rich - you may get a check engine at some point , or worse, a clogged converter honeycomb. Not ideal for the engine condition, so it's something to look after. If a new converter is needed, genuine ones are not affordable, aftermarket ones come with the flexible downpipe and the quality varies
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
SRS module is somewhere down there under the armrest. Any warning lights on the dash display?
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
Clogged cat? Well, the test is to remove the front/ upstream O2 sensor and screw in a pressure gauge.start the car and If it reads 5-6 psi your catalytic converter is clogged. Normal it will read between 1-2 psi. I have heard of a few hillbillies around here soaking there cats in laqeur thinner. Not for the average DIY person though I know. MDK
oragex
Post by oragex »
I'm really not sure about the following, but I've heard once that it may not be a good idea to drive through deep puddles of water - like when there is some flooding or alike. The catalytic converter works at very high temperatures, and the ceramic elements inside may not take well a sudden temperature change as the water cools down the unit. If the ceramic honeycomb inside cracks and breaks in small pieces, it can clog it. Again, not sure about this, but worth remembering.
Dynamic D
Post by Dynamic D »
Here is an update:
I've changed the cat 6 weeks ago or so.Therefore I doubt that it is a problem with the cat (Bosal), but who knows... I've verified and the heat shield is no longer there. I also have an engine code P1137.
I think I would start by trying to find a new heat shield and O2 sensor and in the meantime, I will try not to go for too long rides. What do you think ?
The O2 sensor is easy to find, but any ideas where to find the heat shield ? I even looked at the volvo web parts and I don't see it there.
Any ideas ?
Thanks !
Dynamic D
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
as stated above, you have two problems, rich mix causing hot burn off in the cat and no shield. replace the ox sensors and maby skip the shield. Has you milage been lower?
oragex
Post by oragex »
Heat shield is tricky, there get loose where it's attached to the chassis (aluminum foil just rips off). Junkyards usually remove the front pipe so not sure if they leave the front heat shield, but you may use a piece from the rear ones. Try perhaps at Kennyupull nearby. Is that a non turbo? I got a front O2 NGK (same as NTK) from Ebay, just careful not to trust ebay sellers with the compatibility (year/engine), rather use Fcpeuro to check the fitting. Eeuroparts.com can ship with UPS World Ease which has all import fees paid upfront
