IPD sale Volvo Parts
XeMODeX - Experts in Volvo Electronics My Swedish Parts ad - genuine Volvo parts
Did you know? 🤔
Unable to get Vida into Control Module Adaption
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
GregAivaliotis
Year and Model: 2011 XC90
Has thanked: 0
Been thanked: 0
Australia
GregAivaliotis
Post by GregAivaliotis » Sun May 05, 2019 1:38 am
Can anyone help,
I don't have the the option in Vida to put it into CMA. I only have the option for reset adaption , and oil counter
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 44 times
United States of America
ggleavitt
Re: Unable to get Vida into Control Module Adaption
Post by ggleavitt » Mon May 06, 2019 10:35 am
Car connected, go to TCM and select reset adaptation, should open a new window for the adaptation verbiage. On the left side of the new window is a grayish spotty drawing of a VTC2000 box, it's really an icon. Press the "icon" and see if you get to the procedure. If not, back out and go to the Repair section and find the transmission post replacement checks, adaptation is in one of them. Need lots of clear space to get through the shift points, and lots of time to do the runs (industrial park on the weekend works great). Car will indicate when specific tests have been completed.
I'm guessing that you're doing the adaptation for a reason other than replacing fluid (counter reset only).
Good luck
2005 2.5T AWD-195k
2008 V8 AWD Sport-125k
GregAivaliotis
Has thanked: 0
Been thanked: 0
Australia
GregAivaliotis
Post by GregAivaliotis » Tue May 07, 2019 3:51 am
Thanks for the reply, I have attached a photo of the option I have ,
Is this it, as I do not have the option to do the driving testing in all gears and have the Yellow triangle come up as I've seen in other posts and Videos.
Thanks for the help so far, just trying all things before having the tranny replaced
Ive had the torque converter replaced and the valve body , both at different times, but within an 18 month period and still have shift flare and the occasional shudder at 1500rpm, so much better now that the oil has been changed again. Sho said no metal in the oil when they drained it
ggleavitt
Has thanked: 0
ggleavitt
Post by ggleavitt » Tue May 07, 2019 7:37 am
My bad, what I get for trying to do this from memory.
Car connected, go to Diagnostics/Vehicle Communication, select TCM and in the lower tabs select Advanced.
You should see a list of items under Advanced, "Activation of adaptation" is at the bottom. If you select it, you'll walk through a couple prerequisites, then the activation window page should pop up.
Let me know if this works .
Thanks
2005 2.5T AWD-195k
GregAivaliotis
Has thanked: 0
Been thanked: 0
Australia
GregAivaliotis
Post by GregAivaliotis » Sat May 11, 2019 5:27 pm
Still no good , only get the options shown in the previous photo
ggleavitt
Has thanked: 0
ggleavitt
Post by ggleavitt » Sun May 12, 2019 8:24 am
Show me your version of this screen please-
TCM Adaptation VIDA.jpg (142.26 KiB) Viewed 239 times
2005 2.5T AWD-195k
GregAivaliotis
Has thanked: 0
Been thanked: 0
Australia
GregAivaliotis
Post by GregAivaliotis » Sun May 19, 2019 12:38 am
Here is the options I have
I only have three
Year and Model: Lots
Has thanked: 4 times
Been thanked: 96 times
Australia
Post by precopster » Sun May 19, 2019 3:50 am
Could be this adaptation is only applicable to the AW55-50/51SN and not the TF-80SC as fitted to later models
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
GregAivaliotis
Has thanked: 0
Been thanked: 0
Australia
GregAivaliotis
Post by GregAivaliotis » Sun May 19, 2019 4:23 am
Ok thanks , I wonder if there is anybadaption for the 80Sc
Australia
Post by precopster » Sun May 19, 2019 5:27 pm
Had a look at my Vida 2011A on my desktop and it includes the adaptation for the 3.2 litre with TF-80SC.
What version of Vida are you running there?
adapt 2011A.JPG (99.24 KiB) Viewed 182 times
