Fuel pump relay location
- Been thanked: 504 times
No relay.
The XC90 uses the PEM.
It is either in the RR wheel arch (behind the liner) or inside the car.
https://volvoforums.com/forum/volvo-xc9 ... ial-71534/
If you think you need a PEM, try junk yard or ebay (used is about $40-$50).
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Did a thread on this last year- https://forums.swedespeed.com/showthrea ... M-Location, couple places these live before permanent relocation inside the car.
The forum search tool has a couple other entries relating to PEM. One example- viewtopic.php?f=10&t=87719
As far as testing, it's a PWM signal from the ECM to the PEM and then to the pump (on demand) with 12V coming from the CEM, can see a schematic in the photo link in the first post. I would first look really closely at the PEM connector interface and see if anything is obvious, much of what is written on failure is due to outright corrosion.
Quite a few options for replacement, if you buy used after 2007, you're pretty much assured that the unit has never been outside the car.
Good luck
Good luck
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Can buy a used one off Ebay for like $60 - look for one without corrosion on the metal plate. No programming. If you have an FPS may also get a replacement one
- 5075 Views
Last post by wizechatmgr
- 4088 Views
Last post by Lowmiles
- 2813 Views
Last post by 93Regina
- 9912 Views
Last post by Simone
- 7909 Views
