IPD sale Volvo Parts
Did you know? 🤔
98 V70 glt indicator fuse
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 2 times
Been thanked: 0
United States of America
stephansvolvo
Post by stephansvolvo » Mon May 06, 2019 5:21 pm
The other day my turn indicators stopped working. I checked the fuse. Blown. So I put another in. Today that one blew. I replaced it and it blew again.
Not sure why this is happening all of the sudden. Any thoughts?
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
1998v70xcbill
Year and Model: 1998v70xc
Has thanked: 0
1998v70xcbill
Re: 98 V70 glt indicator fuse
Post by 1998v70xcbill » Mon May 06, 2019 6:09 pm
Possible short at light blubs or socket. Then check wiring near bulbs
Remove all light blubs (turn signals) and then try new fuse.
stephansvolvo
Been thanked: 0
stephansvolvo
Post by stephansvolvo » Mon May 06, 2019 10:56 pm
Yes. I thought I’d start there as well. Just came out of nowhere. So I thought it was weird.
Thank you for your input.
Stephan
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 17 times
Been thanked: 29 times
BEJinFbk
Post by BEJinFbk » Tue May 07, 2019 1:22 am
Just to keep things interesting - That fuse handles more than the directionals:
98 S-V70 Fuse Locations and Legends.pdf
(678.65 KiB) Not downloaded yet
RickHaleParker
Has thanked: 3 times
Been thanked: 296 times
RickHaleParker
Post by RickHaleParker » Tue May 07, 2019 2:08 am
Which fuse?
I am counting at least three it could be.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
stephansvolvo
Been thanked: 0
stephansvolvo
Post by stephansvolvo » Tue May 07, 2019 8:56 pm
Which fuse?
It’s number 27 in the fuse box under the bonnet. Not the relays. It is the backup lamps and turn lamps
Stephan
stephansvolvo
Been thanked: 0
stephansvolvo
Post by stephansvolvo » Tue May 07, 2019 8:58 pm
Everything in this box seems to be good to go. Unless it’s a relay that’s giving me the issue which could be bustin the fuse.
Stephan
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue May 07, 2019 10:59 pm
11C/27 Wiring, lamp sockets, Bulbs or Gear Position Sensor.
BEJinFbk
BEJinFbk
Post by BEJinFbk » Wed May 08, 2019 7:40 pm
Does it blow immediately? When you turn on the key? When you use signals?
And - Just for grins, unplug the hazard light switch and see if you still blow fuse 27.
If it fails, you may have a backup light issue, if not, you're probably still chasing turn signals.
Klausc
Year and Model: 1995 855 Turbo
Been thanked: 7 times
Klausc
Post by Klausc » Fri May 10, 2019 2:18 pm
If you have a lot of fuses, just push the hazard light button and see if the fuse blows. The key does not have to be in the switch. Remember, the relay for the turn signals is part of the hazard switch.
Klaus
