IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
No Oil Pressure - Stop Engine
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
Year and Model: 2004 V70 2.5T
Has thanked: 0
Been thanked: 82 times
United States of America
Re: No Oil Pressure - Stop Engine
Post by cn90 » Wed May 08, 2019 8:44 pm
Look into the O-ring issues.
This is from a 2000 XC, but it is very similar to your 2005 XC O-ring:
viewtopic.php?t=31236
oragex
Year and Model: S60 2003
Has thanked: 82 times
Been thanked: 189 times
Canada
oragex
Post by oragex » Thu May 09, 2019 4:28 am
Metallo wrote:
Wed May 08, 2019 6:25 pm
Last point, the engine is noisier now, it sounds like a diesel...well, maybe not as noisy but you know what I mean.
Not to sound pessimistic but this is not always good news. If you pause at 25:40 on this video, you can see the pressure sensor at the bottom of the image, at the right of the red power cable, it's tiny and has a wire to it. I think you can remove it with the manifold in place www.youtube.com/watch?v=3fEjbMpVSfo
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 1 time
Canada
Metallo
Post by Metallo » Thu May 09, 2019 5:04 am
Well, I do have an '05 and an '06, I can still try to undo the sensor from the 05' and try it in the '06, at least I know if the oil sensor is the problem or not. If the oil sensor is the issue, I guess the car should start and give no warning lights and/or VIDA messages.
I can try this on Saturday and see where does it take.
Alex
Polar 940 Turbo SW - 1997
XC 70 AWD 2.5 - 2005
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 200 times
Been thanked: 647 times
Trinidad & Tobago
Post by abscate » Thu May 09, 2019 7:28 am
Alex, check the fitment pages between 2005 and 2006 to see if the parts are identical for certain.
I’m pretty sure They are.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
jimmy57
Has thanked: 2 times
Been thanked: 163 times
jimmy57
Post by jimmy57 » Thu May 09, 2019 7:55 am
Oil light + message + cam control code + extra noise is an open and shut case of low oil pressure. Drop the pan and inspect the o rings for oil pick up tube and the ones from pump to oil filter housing in pan. Also the ones where pan fits to intermediate section (block). Look to see if there is metal from bearings. If there is metal then you have serious problem and repairing that engine will exceed the cost of a used engine with similar or less miles. By the way, if you get a used engine those same o rings should be changed.
Metallo
Has thanked: 1 time
Canada
Metallo
Post by Metallo » Thu May 09, 2019 11:21 am
I see that many of you lean to the o-rings more than the sensor, I may ask a silly question here but...if the o-rings are the culprit, shouldn't I see a leakage or have any other alerts before you get the problem ?
Or the car is expected to work fine till one minute ealier and then stops?
Alex
marcus
Year and Model: S60 2002
Has thanked: 10 times
Been thanked: 0
marcus
Post by marcus » Thu May 09, 2019 12:14 pm
It could happend that the inlet mesh for pump screan in cloged. You will have to take out the oil sump to have a look. Or the oring in the oil sump are bad. There is 5 of them on the oil rout before it goes to engine.
Has thanked: 0
Post by cn90 » Thu May 09, 2019 7:01 pm
Look at the link I posted above.
O-rings, if defective, leaked INTERNALLY (thus low oil pressure), it does not leak externally (thus no oil on driveway).
amblerman
Year and Model: 1999 s70
Has thanked: 1 time
Been thanked: 16 times
amblerman
Post by amblerman » Thu May 09, 2019 10:13 pm
To expand on what cn90 said, if you look at the link provided, you'll see that the o-rings in question connect and seal various tubes and channels in the oil pan.
Those seals are critical for maintaining oil pressure in the plumbing of the oil pan as the oil pump tries to pump and circulate oil up into and through the engine.
If the inlet mesh of the pickup tube gets sufficiently clogged, then the oil pump can't pick up and pump enough oil at the proper pressure.
If the o-rings fail or get brittle and no longer seal properly, then the oil pump may be pumping ok but all the oil flows past the failed o-rings and back into the pan instead of up and into the engine.
BTW if you want to see what a failed o-ring in an oil pump can do , watch this video about a blown high performance Mercedes engine. No this isn't a volvo, but the principles are the same and he does a great job of explaining what an oil pump does and how a tiny o-ring failure leads to a failed engine.
Skip to 6:50 mark to get to the oil pump description
The o-ring failure description starts at 8:15
The whole series of the engine rebuild is quite something:
rebuild playlist:
-A (edited for spelling)
Metallo
Has thanked: 1 time
Canada
Metallo
Post by Metallo » Sat May 11, 2019 10:41 am
Hi guys,
I am trying to locate the oil pressure sensor, I did follow VIDA instructions, lift the car and then remove the side air baffles, then the central one.
They say to disconnect the connector and unscrew the oil pressure sensor.
It looks easy, only a few lines, but I cannot see the bloody connector.
I watched the video posted in this thread but you need to remove the manifold to get there.
If VIDA says to access it from under the car, it means if should be the easiest way to access it.
Any suggestions? Thank you.
Alex
P.S.: I can see the sensor after I removed the splash screen, I guess VIDA (for the first time in my own experience) is wrong.
