Really foggy windows
TheOtherside
Year and Model: 1998 V70R
Has thanked: 55 times
Been thanked: 5 times
Post by TheOtherside »
Not sure why but my windows always fog up in my 98 V70R.
It's almost like it fogs up worse when I have the climate controls turned on.
Any idea why?
I cleaned the inside and outside of the windows too, still does it.
Thanks,
Justin
98 V70R
13 Flex w/EcoBoost
TheOtherside
Also, I smell coolant in the cabin now that om paying attention to it...
98 V70R
13 Flex w/EcoBoost
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
Either the HVAC drain is clogged or the heater core is leaking which sometimes tends to leave a film on window.
TheOtherside
crlande wrote: 10 May 2019, 16:56 Either the HVAC drain is clogged or the heater core is leaking which sometimes tends to leave a film on window.
Thank you so much! I'll start looking!
98 V70R
13 Flex w/EcoBoost
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
When you wipe the windows down is it a bit white and potentially a bit milky? If so, that is most definitely your heater core.
Good luck!
TheOtherside
wizechatmgr wrote: 10 May 2019, 17:16 When you wipe the windows down is it a bit white and potentially a bit milky? If so, that is most definitely your heater core.
Good luck!
I'll look! What should I wipe them with? Windex? Should I wipe them down with the climate control on or off?
Thank you guys for the help!!!
98 V70R
13 Flex w/EcoBoost
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
best to order online a Bahr or volvo heater core. dont source local or allow your mechanic to decide.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
TheOtherside wrote: 10 May 2019, 17:18 I'll look! What should I wipe them with?
A clean dark colored cloth with nothing on it. You are trying to find out what the color of the stuff stuck on the windshield is and nothing more.
Active
Past
TheOtherside
tardcart wrote: 10 May 2019, 17:27 best to order online a Bahr or volvo heater core. dont source local or allow your mechanic to decide.
I'll look! Thank you kindly!
98 V70R
13 Flex w/EcoBoost
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
it is an easy DIY job. just be sure to have two large bags under the heater core if you pull it pr you will have quite some water running where it is hard to dry out.
1996 855 R,
2010 V70 D5,
