IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
2005 XC90 T6 Executive Project Car.
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
Roger_850T
Year and Model: 854T 1995
Been thanked: 15 times
Re: 2005 XC90 T6 Executive Project Car.
Post by Roger_850T »
I'm at a loss. I can't find your pipes that bulge in the parts listing, the parts listing only looks like what I posted before. What's on the bottom of your "bulge" parts?
Other question: is you XC90 US Spec, or elsewhere? One would presume US Spec, since you're in Kansas, but sometimes one never knows...
Roger
'05 XC90 V8 140k
'95 854T 310k
'02 V70 159k
'03 S80 111k (crashed)
'93 945T 217k (gone to be parted out)
'87 245 300k+ sold, still going
'84 264 Diesel, RIP at 160k
'78 242 manual everything.
'73 P1800ES, fun until the rust set in...
Roger_850T
Is there any volvo p/n on the plastic "bulge" part? Tha might help inform a cross-reference.
Roger
'05 XC90 V8 140k
'95 854T 310k
'02 V70 159k
RickHaleParker
Has thanked: 3 times
Been thanked: 621 times
Post by RickHaleParker »
It is "US Spec". Volvo AME partner group to be precise.
Go back to page 3. I think you missed a post.
2004 S60R, B8444S TF80 AWD.
RickHaleParker
Project put aside as I get the '98 C70 ready. She going to take the C70 to visit her brother who lives 1200 miles away in Virginia.
After that, I'm going with Option 2: Forge ahead on the engine, Plugs, PCV. Timing Belt service and possibly a new set of injectors. Deal with the exhaust system later if it turns out it is restricted.
RickHaleParker
Got the intake manifold off today. The Banjo is plugged up.
Ordered:
Volvo PCV Breather System Kit - KIT-P2XC90T6PCVK1
Six Bosch Spark Plug - Bosch FR7DC.
OEM Fuel Filter - Hengst 30636704
Set of 6 Remanufactured and flow matched Bosch 0280155831 fuel injectors.
While I'm waiting for the parts to, replace any questionable vacuum hoses, Clean the intake manifold, ETM charge pipes ... etc.
RickHaleParker
Went to change the Oil Trap on this 2.9 today. The lower bolt appears to be behind the alternator mounting bracket.
Can somebody that done one, confirm this is the case or tell me otherwise?
PS: Never mind, I found the notch in the mounting bracket that give one access to the Oil Trap bolt.
SuperHerman
Been thanked: 174 times
Post by SuperHerman »
On the plastic intake pipe: On mine, with about 150k, while chasing turbo charger over boost issues, I found mine was also leaking a bit of air through the seals. For a short term fix I took copper wire and wrapped around the plastic so that the seals would compress. I bought a new part from the dealer for about $175.00.
During the process I learned that the type on our car is the upgraded part - it has the baffles. Apparently these are to lessen the turbo whistle as owners were complaining about it to the dealership. That said, one can source a used plastic intake pipe from an early model S80 which does not have the baffle, hence no seal. (I would not buy a used upgraded part as the seals most likely are no better). I read about one person who did the backwards design swap with success and liked the slight spool up sound. I just wanted the issue resolved so I bought the new part. If you have easy access to a wrecker it may be worth buying the early design - just make sure the rest of the plastic is solid, especially at the joints where it mates to the AL runners.
I did not find any reference to replacement seals. I also expect the design anticipates some leakage - otherwise they would not have used the seals. How much - who knows. I do know that before I had work done on mine I did not have any issues with the existing leakage - ultimately my problem was not the intake pipe, but the shop flipped my hoses around.
RickHaleParker
SuperHerman wrote: Mon Aug 05, 2019 3:35 pm On the plastic intake pipe: On mine, with about 150k, while chasing turbo charger over boost issues, I found mine was also leaking a bit of air through the seals. For a short term fix I took copper wire and wrapped around the plastic so that the seals would compress. I bought a new part from the dealer for about $175.00.
I'm thinking a light coat of RTV on both sides of the rubber seal to seal up the baffles.
There is a '04 XC90 T6 at the local PnP, no baffles, $21.00 for both.
SuperHerman
I would go the $21.00 route and be done with it. When I looked I was seeing prices around $50 plus shipping - so for the extra hundred and the fact I didn't want to have issues with a flunky part I bought new. You can always try the RTV if you don't like the "cool kid" whistle.
RickHaleParker
RickHaleParker wrote: Sun May 26, 2019 7:15 pm Fails Intake Vacuum test: No Vacuum, +3 PSI pressure with engine at 4000 rpm.
Medium size vacuum line broken, shares a tree with the intake manifold and the purge valve.
