Hello all,
There is a loud knocking noise coming from my 2009 Volvo XC70 3.2L AWD. The noise only occurs during acceleration. The knocking pauses for a split second when it switches gears. It seems it only knocks when the engine is under load. It occurs in both drive and reverse. It also occurs when the car is in drive/reverse and I give it throttle while applying the brake so it doesn't move. In neutral, the knock is less distinct.
Water pump has been replaced, idler and tensioner pulley replaced, serpentine belt replaced. Mechanic says engine mounts look fine.
Currently running 10w40 synthetic. Knocking becomes louder after car has warmed up. When cruising (not accelerating) the knocking disappears. The car has ~180,000km (112,000 miles).
I have attached a link to a video I took where you can hear the noise, sorry it is not very clear. Please ignore the low fuel light and warning light (unrelated).
Any ideas what this could be?
Thanks in advance
Knocking on Acceleration 09 XC70
tigerscott
- Year and Model: 2000 C70, 2009 XC70
Mine is doing that too. Volvo says it is a wrist pin or crank bearing failing and needs a new engine. Another mechanic says he has seen this in another car, the engine eventually blew, while Volvo is telling me the 32 is bullet proof. I am trying to decide the likely hood that a donor engine will have the same problem. What happened with yours?
Hey, I believe my mechanic had previously mentioned that it could be a wrist pin. He said that it would likely not be worth repairing due to the cost. I am still driving my XC70 daily, have put another 30,000km (19,000 mi) on it and its still going strong. I do however think that the knock has become more pronounced. I found that running thicker oil helps with knocking a little bit.
I don't think it is a mechanical problem with the AWD system, because the knocking still occurs when the engine is revved in neutral.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Check your thrust rod it is likely broken
If it is broken then the mount under it has likely collapsed
You will need to lift the engine a couple of inches to replace the collapsed mount
https://www.freel2.com/forum/topic32979.html
Good luck
Paul
Good luck
Paul
- 2115 Views
Last post by 2002V70XC
- 7111 Views
Last post by dacson
- 982 Views
Last post by Eddienorgard
- 25 Replies
- 4206 Views
Last post by dosbricks
- 2448 Views
Last post by Ou2mame
