I am helping to diagnose the no-start problem of my friend's 1999 V70 wagon.
It ran previously and just died one day, never to run again.
As soon as I figure out all the directions from the Volvo DICE scanner and software I bought I'll use that but in the mean time I want to do some other checks.
There's a Schrader valve that indicates fuel pressure on the fuel rail. The fuel connection is more like a tire connection than anything else.
Where can I find a fitting that nooks up to that and might be connected to a pressure gauge?
Thanks.
Gauge to check fuel pressure on 1999V70
Your local auto parts store (Rock, Oreillys, Advance, Pep Boys) will loan you a fuel pressure gauge with fittings that will work on that Schrader valve
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
In a pinch, a 99 cent tire pressure gauge can be used (and then thrown away).
Knows enough to be dangerous
