Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
ATF JWS3309 Service Method ?
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 23 times
United States of America
vtl
Re: ATF JWS3309 Service Method ?
Post by vtl » Thu May 16, 2019 1:10 pm
Be aware that too much modifier may glaze the friction plates and they start to slip.
2005 XC70 250k
2016 XC60 40k
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 27 times
MDK
Post by MDK » Thu May 16, 2019 3:03 pm
Thanks for the post on "too much" lubegaurd VTL. I was wondering about that. Someone was talking about adding a little REDLINE after a full flush.
Archer
Year and Model: 1998 V70 T5/S70 T5M
Has thanked: 0
Been thanked: 3 times
Archer
Post by Archer » Fri May 17, 2019 7:18 pm
Yikes...I thought 1 bottle was, more or less, recommended or an 1 oz per liter of atf.
vtl
vtl
Post by vtl » Fri May 17, 2019 8:25 pm
Mine started slipping slightly after about 4 oz into original 1161640 ATF, which I'm suspecting for having extra modifiers compared to other T-IV like ATFs.
Glazing is easy to fix: replace ATF, let HFM wear out. It is naturally wears out along with the friction material, and is replenished from ATF.
2005 XC70 250k
2016 XC60 40k
MDK
Has thanked: 0
MDK
Post by MDK » Mon May 20, 2019 4:48 pm
MDK...so after reading you all's post about the lube gaurd additive. And one man was saying even a 10 oz bottle may cause it to slip over time. Add to the fact that I just did a full flush on both my 2002 V-70 non turbo and my 2004 R car. I've decided to put 1/2 a bottle in one..half a bottle in the other. .. rolling on.
Mikele82
Year and Model: XC70 2004
Has thanked: 18 times
Been thanked: 2 times
Mikele82
Re: ATF JWS3309 SERVICE METHOD ?
Post by Mikele82 » Tue Jun 11, 2019 3:32 pm
EngineeringBloke wrote:
Mon May 13, 2019 8:21 pm
Note. Some have recommended that for older transmissions, it is gentler to them to just do the drain and fill. But then to repeat the process after a few weeks or months. This dilutes the older fluid to 50%, 25% 12.5% and so on at each change.
I'm at 180k miles (2004 xc70). gears shift well on plain and downhill, but uphills feel like a slip here and there, more than usual.
My fluid has lost its "pink hue" and now looks a bit toward brown (not dark yet).
Volvo dealer service, Firestone and jiffy lube say not to flush transmission fluid and that they rather not do it (Firestone said they won't at all), saying transmission might fail after a flush.
I guess doing the pan drain/fill wound be best in terms of my car. ("dilute it" every few weeks)
If I dont know what fluid originally was put in, is it ok to mix with the other 3309 brands or should i do Volvo OEM ATF?
Also, seems easier t odo the Flush method.
you think doing that method for just 4-5 quarts would be better ?
https://www.ipdusa.com/files/product/13 ... CTIONS.PDF
vtl
vtl
Post by vtl » Wed Jun 12, 2019 8:24 am
Volvo OEM ATF is the best, Idemitsu Type-TLS is a good match.
You can do 3 drain'n'fills, need about 12 quarts for that. Less mess and still is good enough.
2005 XC70 250k
2016 XC60 40k
Mikele82
Mikele82
Post by Mikele82 » Wed Jun 26, 2019 12:28 pm
Is this Seafoam tune up product compatible with Volvo OEM ATF fluid or other jws3309 fluid?
https://seafoamsales.com/7-things-to-kn ... rans-tune/
Ipd snippet:
"He suggested a Sea Foam transmission additive product that he has used in his own Volvo with good effect. I added it to the tranny and within a few days, the "Transmission Service Urgent" message went away and"
https://www.ipdusa.com/blogs/165/ipd-sh ... ts-dealers
vtl
vtl
Post by vtl » Wed Jun 26, 2019 12:31 pm
Do not add any "tune up" product to ATF. Better change ATF.
These users thanked the author vtl for the post:
Mikele82
2005 XC70 250k
2016 XC60 40k
