IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
Oil in plugs
TheOtherside
Year and Model: 1998 V70R
Has thanked: 55 times
Been thanked: 5 times
Oil in plugs
Post by TheOtherside »
Is this normal?
I'm hoping it's just from spilling oil?
Hoping......
98 V70R
13 Flex w/EcoBoost
Clemens
Has thanked: 97 times
Been thanked: 57 times
Re: Oil in plugs
Post by Clemens »
nope, this is usually pcv blowby. It is either from the vacum tube the you see coming from under the intakte manifold (check if it is loose on top of the motor) or most likely from the oil filler cap gasket getting hard. Have you cleaned your PCV system lately? If not, it might be about time...
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Re: Oil in plugs
Post by tardcart »
sometimes you need a new cap besides the cap rubber even with functioning PVC. but thats a weakness of these cars. supposed to be serviced at 60k miles I think. (PVC}
TheOtherside
Re: Oil in plugs
Ohk! Thanks guys! I'll check the cap when I get home!
Should I check the hose right next to the cap?
98 V70R
13 Flex w/EcoBoost
tardcart
Re: Oil in plugs
Post by tardcart »
the head vent hose almost looks like it has a hole drilled in it on the top? It should be oiteker clamped tight and no cracks or holes. its under about 10 pounds of pressure when the turbo is kicked in even with an unclogged PTC. due to blow by and turbo pressure traveling down the vacuum line from the intake manifold to the PTC, The minimum would be check the hose and get a cap rubber and leave the cover off to monitor and put a rubber glove on the oil fill to check for crankcase pressure. search "glove test"
quietlymknnoise67
Year and Model: 2003 C70
Re: Oil in plugs
Post by quietlymknnoise67 »
Get the upgrade cap gasket from IPD
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 376 times
Been thanked: 1176 times
Re: Oil in plugs
Check both the cap and the PCV hose.
Also, your plug gap seems huge - should be down at about 0.028 " or 0.7mm
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
TheOtherside
Re: Oil in plugs
Thanks guys. So, the cap gasket is on the actual oil fill cap?
98 V70R
13 Flex w/EcoBoost
tardcart
Re: Oil in plugs
Post by tardcart »
TheOtherside
Re: Oil in plugs
Yeah, that hose popped right off. No effort.
Do you guys recommend me waiting to get new plugs until I figure this out, or should I get new ones now?
98 V70R
13 Flex w/EcoBoost
