2006 V8 Brake Caliper Upgrade
Hello. I was reading over this post here, https://forums.swedespeed.com/showthrea ... 302?page=3 , and I had a question. I’m just about to upgrade my calipers from the 316mm rotor size to the 336mm rotor size. My biggest concern is going to be the pressure line that holds the brake fluid. My thought is that I would swap the line from the old one to the new one as fast as I can that way no air gets into the Master Cylinder. How do I best go about doing this swap?
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
You are going to need to bleed the brake calipers regardless.
- 15 Replies
- 6432 Views
Last post by wizechatmgr
- 233 Views
Last post by MotorSurgery
- 638 Views
Last post by dosbricks
- 20 Replies
- 5679 Views
Last post by confused_al
- 2080 Views
