The car 1998 Volvo V70T5 with about 125,000 miles.
First start when cold is fine. After warmed up, I have to try to start it twice for it to start. If I turn on the key, then stop and adjust seat and fasten seat belt, then hit start it start right up. There is a bit of a gas smell when it starts.
I’m thinking I’m needing to give the fuel pump sometime to build up fuel pressure before it will start.
This has gone on unchanged for 6 months. Recently it has started to die, while at idle. Car starts right up and goes on about it’s task.
I suspect the 2 things are related.
Any guidance
Robin
I'm Thinking This Is Fuel Pressure Related
- Been thanked: 4067 times
Three parts of the P80 series fuel system that age.
Fuel pump relay ( checked by jumping with wire)
Fuel pump regulator ( vacuum controlled)..pull hose and sniff for fuel
Fuel pump ..diagnose by exclusion and fuel pressure measurement
- RickHaleParker
- Been thanked: 979 times
Is the temperature gauge right?
On a cold start the Air/Fuel is rich. If the ECM thinks the engine is cold it will try to do a rich air/fuel mixture on a warm start.
Active
Past
Past
- RickHaleParker
When was the last time you clean out the Idle Air Control valve?
Active
Past
Past
- 16198 Views
Last post by Richard99
- 865 Views
Last post by E Showell
- 434 Views
Last post by RickHaleParker
- 266 Views
Last post by maxnix
- 7985 Views
Last post by adrian22
