IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
Lower control arm and CV boot, should I bother?
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 72 times
United States of America
vtl
Re: Lower control arm and CV boot, should I bother?
Post by vtl » Fri May 17, 2019 9:49 am
Outer CV needs a different type of grease. Inner one (tripod) can use the grease from the GKN rebuild kit, however don't use it in outer joint.
I don't remember what exact grease does the outer require.
For inner joint you better get a GKN grease as well. I destroyed two axles by using a very expensive but wrong CV grease :)
These users thanked the author vtl for the post (total 2):
XC70Ridergcha8e
05 XC70 265k, 16 XC60 45k, 19 Tundra 5k
BlackBart
Has thanked: 76 times
Been thanked: 58 times
Sweden
BlackBart
Post by BlackBart » Fri May 17, 2019 9:52 am
vtl wrote:
Thu May 16, 2019 5:54 pm
I think one of the most expensive ($200ish) was Raxles, and it was not good.
That's interesting info. The Audi guys love him, I have one on my A4, rebuilt with factory parts.
These users thanked the author BlackBart for the post:
XC70Rider
1994 850T wagon
Is it time for a 1964 122 wagon?
XC70Rider
Year and Model: 2007 XC70
Has thanked: 20 times
Been thanked: 19 times
XC70Rider
Post by XC70Rider » Fri May 17, 2019 9:52 am
Both kits come with 2 packs of grease so I'll use them. Thanks for the heads up. :mrgreen:
vtl
vtl
Post by vtl » Fri May 17, 2019 10:00 am
Hand-made vs mass-production with expensive quality checks.
Once in a while, GKN can be bad too, btw...
Year and Model: 2004 V70 2.5T
Has thanked: 0
Been thanked: 137 times
Post by cn90 » Fri May 17, 2019 4:35 pm
Same grease in both inner and outer CV joints.
Nothing special about the grease. I have used HD Castrol grease on the joints for 25y, zero issues.
vtl
vtl
Post by vtl » Fri May 17, 2019 8:16 pm
You'll notice soon enough if you put molybdenum disulphide grease into tripod joint.
gcha8e
Year and Model: 2005 S60 2.5T AWD
Has thanked: 16 times
Been thanked: 2 times
gcha8e
Post by gcha8e » Mon May 20, 2019 10:29 am
Thanks for the input, I have a lot of videos and learning to do.
A while back I got cheap control arms on Amazon made by Bapmic. Just working up to the install.
https://www.amazon.com/gp/product/B075S ... UTF8&psc=1
Did I make a mistake with that control arm? Will the bushings hold up? (the reviews of the product were good so I went with it)
The ball joints seemed to look good so I did not order replacements.
with the CV boot I'm looking at the inner boot mainly I think it's released most of it's grease. I would love to just add the grease without removing the axle but I think it's right between the frame and everything else...... I'll have to get underneath and see if this is doable to get the clamp at the right angle to finish the job and re-tighten. perhaps there is hope!
vtl
vtl
Post by vtl » Mon May 20, 2019 10:46 am
You can slack the clamp, inject grease with a syringe, rotate the clamp at needed angle and re-tighten it. However they tend to stretch over time and need to be replaced. Have both my 2 and 3 y.o. Volvo and GKN axles spitting small amounts of grease, the clamps are fully tightened, can't do more.
These users thanked the author vtl for the post:
gcha8e
gcha8e
gcha8e
Post by gcha8e » Mon May 20, 2019 12:20 pm
If I can replenish the grease every few years... hell yeah. Same as the oil leak..... just add more, don't run dry....
Has thanked: 0
Post by cn90 » Mon May 20, 2019 1:07 pm
vtl wrote:You'll notice soon enough if you put molybdenum disulphide grease into tripod joint.
Not true.
Mechanically, same engineering issue, same lubrication requirement for both inner and outer CV ball bearings.
The problem with INNER, especially L side: it is close to engine heat. I usually use the grease package that comes with GKN boot. However, I have used Castrol HD wheel bearing grease in many vehicles for the last 15 yrs. Zero issues.
CV joints fail mostly from a breach in the rubber boot, allowing debris to enter.
