small evap leak
Randall0208
- Year and Model: 2000 volvo s70
- Has thanked: 1 time
Hey there, I got a check engine light code p0456 for a small evap leak. I read about it and some common things were the fuel cap and the canister purge valve. I bought a new canister purge valve and the problem persisted so I bought a new seal for my gas cap, not a new cap just a new seal. The new seal went on fine and was the exact same thing as what I took off so I don't think that's an issue... After replacing those 2 things I cleared the code and it took a couple days before it came back. I'm already out $50, does anyone know what may be causing the problem and where I should go from here? Thanks.
- DeadEric
- Year and Model: 1996 850 Turbo
- Has thanked: 2 times
- Been thanked: 12 times
Find a shop that will do a smoke test on the evap system. Shouldn't be more that $70 to $100. Sounds like a lot but it's better than guessing at replacing the rest of the parts.
- 1628 Views
- 719 Views
Last post by Ozark Lee
- 2648 Views
- 946 Views
Last post by benpineapple
- 668 Views
Last post by essjaygee
