1999 S70 Head swap
farzadm
Year and Model: 1999 s70
Post by farzadm »
First post here as I need some help and direction.
1999 S70
B5452S engine, distributorless (ignition coil)
Timing belt slipped and bent valves so needed to swap the head, looked online and found a supplier. Provided my details 99 S70, B5452s and purchased the head.
After installing the head I realized the camshafts from my original head did not sit. Concerned I double checked ( hind sight should have done this prior to installing the head) the head and it did not match my original head at the top end, needed new cams, engine mounts even the intake holes were squarish and cam cover.
I was ready to remove the head, but the supplier said it’s ok and will work with compatible cams and sent me the cams, I got the camcover and different engine mount (metal bracket).
The cams I received came with 2 end caps one a half circle and another a metal disc ( I now know that these are for a distributor system, the disc for the distributor and the half round on the exhaust for the cam sensor)
I installed cams and timing, cover mounts etc and now am stuck with the can sensor piece. The head supplier told me to install the half round piece on the intake cam, and source a sensor similar to what I originally had (cast housing) but with a plastic housing and the sensor with a connector, and to cut the old Sensor wire and attach them to the plastic sensor connector and install that sensor.
I did that but I have a no start condition, grounds are solid, ocassionly I will get a backfire.
I like to understand what is wrong ? I suspect the cam sensor is not correct for this set up. Because the half round metal ring does not come close to the pick up on the sensor also, I can not put the original end cap as that needs another slot on the cam to sit right.
Question is the camshaft sensor right ? What else should I be checking ? Do I need to change the camshafts ? Have I got the timing wrong (cam back has the slots aligned, but the crank mark is ahead 4 teeth below)
farzadm
Post by farzadm »
farzadm wrote: 17 May 2019, 05:54 First post here as I need some help and direction.
1999 S70
