Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link
Buy your stuff using this and it helps MVS!
OEM Tool kit screwdriver: Why?
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 230 times
- Been thanked: 761 times
Re: OEM Tool kit screwdriver: Why?
Who still has the pair of Michael Jackson gloves from their tool kit?
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 15 times
- Been thanked: 21 times
Tip and/of Trick:
All of my Volvos except my 1999 S70 have had a place on the wheel where the pin on the rotor could engage and line up the lug holes properly. The 99 S70 wheel have no provision for accepting the alignment pin. A guy at a tire store gave me an aluminum alignment tool that is threaded on one end and rounded on the other which works just fine - when I can find it...
I used to have to mount heavy x-ray tubes to overhead gantries that had four bolts in the back. Once you got one bolt in, the other three were easy, but that first one was a real bitch holding a 70 lb weight at chest height. A more experienced guy showed me that you could take a standard bolt and grind the head off to make an alignment tool. You thread that in by hand, hang the weight on it, align the other bolt holes and then remove the alignment tool and replace it with the last bolt.
I was going to get a long bolt the same thread as the lug nut and cut the head off, but the tire guy did me a favor by handing me the exact tool.
1998 V70 Non-Turbo/Auto
1993 945 Turbo/Auto
1999 S70 T5 Turbo/Auto
All U.S. market models.
All on the road and running.
PM me if you are near Philadelphia.
1993 945 Turbo/Auto
- gmh
- Year and Model: 97 850 R Wagon
- Been thanked: 12 times
You do not have the required permissions to view the files attached to this post.
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-present)
2014 XC60 T6 (2017-present)
1969 145S (1987-91)
1973 145E (1989-90)
Im not putting my hands in those.....looks like the Wicked Witch of the East...
- wizechatmgr
- Has thanked: 22 times
- Been thanked: 53 times
Whatever you do, don't lose a single glove... =)
1999 V70 XC AWD - ~183k miles
- Clemens
- Has thanked: 73 times
- Been thanked: 40 times
first the screwdrivers. and now the gloves. where are mine? but then, I have a really nice leather bound booklet for my manuals that only the R models got. ha! who's fancy now, Steve?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
- Year and Model: 1995 855 Turbo
- Been thanked: 11 times
There are no flat screws in the 850/s70 and only 1 Phillips head on the entire 850's, none on the S70's. Why would you think that a pin has a function?
Klaus
- Has thanked: 9 times
- Been thanked: 149 times
Maybe the screw driver was a hangover from the old 850 15" rims with the snap in bolt cover. You needed a flat screw driver to remove those.Also, some of the hose clips have phillips/flat options. I still prefer the flat screwdriver option on those as less likely to strip out.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
2006 XC70
- Year and Model: '98 V70 GLT
- Has thanked: 31 times
- Been thanked: 107 times
My GLT has the full tool kit minus the gloves. My 850 had the gloves, but they were nasty... they should have been incinerated.
While we're on this topic, does anyone know what that square rod is with the bottle opener looking thing? I'll take a picture tomorrow, but I've always wondered what it is. In one of my cars (I think the R) it's attached to the jack.
2000 V70R Venetian Red/Charcoal M56 Swapped 191k
2000 S70 GLT Mystic Silver/Taupe 2??k
2003 S60 2.4T Silver/Black 108k
2007 XC90 V8 AWD Sport Titanium Grey/Black 160k
1993 944 Base Beige/Beige 221k
1992 Miata Mariner Blue/Black 146k
1998 V70 GLT Black/Beige 193k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k- Never should have sold it
Need used parts? PM me!
Hook for the spare tire holder perhaps?
Screwdriver viscosity test: Mobil 3309 is not OE ATF
by vtl » Fri May 13, 2016 10:56 am » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 18 Replies
- 1776 Views
Last post by vtl
Thu May 19, 2016 5:56 pm
Why is IPD PCV kit so much more than FCP kit?
by Nick777 » Mon Nov 18, 2019 10:53 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 5 Replies
- 234 Views
Sun Dec 01, 2019 4:05 am
Interesting fact about replacement struts - why are there several OEM part # available
by oragex » Tue May 07, 2019 2:44 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 0 Replies
- 123 Views
Last post by oragex
- 201 Views
Last post by RickHaleParker
Wed Oct 23, 2019 11:47 am
