1998 V70: Remote not working and no alarm
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Hi,
I bought my V70 with a pair of non working remote.
As per the seller, one just needed a new battery while the other wasn't programmed, but I couldn't get any to work :?
Car was built in late 97, and it has the red light on the dash. I've never seen it being lit.
Central locking works fine and I fixed the door lock switches a few weeks ago.
It had an aftermarket alarm, which seemed inactive since I didn't have any of the remotes for it. The alarm featured a LED (K6 and K8 on the schematics), which flashed when I did the remote programming procedure, but the remote still wasn't working.
Thinking the aftermarket alarm could have been the issue, I removed it (what a great day of fun this was :mrgreen: ). It did not make a difference, and I'm not sure what to try next :?:
Could the alarm module be bad and keep the remote from working :?: Or maybe the stock alarm was deactivated (if even possible) when the aftermarket one was installed ? :?:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Newbie here.
Hy. How did you remove the aftermarket alarm ? You post a wiring. Did you find cables on your own installation ? There must be another wiring board more precise, no ?
Manov
Goupil
Post by Goupil »
No factory wires were cut, the aftermarket alarm ones where just soldered right onto them.
I just cut them off, soldered the stock ones if needed and insulated everything.
This schematic is the only one I could find, there's not much with the alarm being at least 10yo from what I could find.
I just found the massive pdf of Volvo wiring diagram for the 1998 x70, i'm off to a good read !
