I've looked across posts related to replacing my 96 850's cooling Fan and while some get close - I haven't found a solid procedure for replacement anywhere on the web. People generally mention that it's simple, and I'm not a mechanic, so that's good.
The Fan won't run, even when hooked up to the battery, so I purchased a replacement.
I'd love to jump in and get this done, so if ANYbody has a procedure I'd absolutely love to hear it.
Thanks!
HOW to replace an 850 Cooling Fan?
- DeadEric
- Year and Model: 1996 850 Turbo
- Has thanked: 2 times
- Been thanked: 12 times
Actual service info for some cars.
1. Remove connector.
2. Remove bolts.
3. Remove fan.
4. Installation is opposite of removal.
It isn't too hard, you just have to get some stuff out of the way 1st. Robert DIY has a video where he takes his out while doing the radiator. I looked on mine and you don't have to remove the upper radiator hose, so skip the removing the coolant part and you don't need to lift the front of the car.
[youtube]
[/youtube]
2. Remove bolts.
3. Remove fan.
[youtube]
[/youtube]
volvocommander
- Year and Model: 1996 850 R
Awesome, excellent reply and I really appreciate it.
When I'm looking at the diameter of the Fan relative to the space I have to pull it up out of the engine - it doesn't seem like I'll have enough space without pulling off the upper radiator hose as well. Is there something I'm missing/misjudging there?
I have the Turbo model, don't think that would effect radiator hose placement, but idk.
- DeadEric
On my 96 turbo it looks like it will clear without removing the upper hose. It will give you more room if you unhook it from the radiator. Might be a good time for a drain and fill of coolant anyway.
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
I don't think you'll have to take out the bottom two torq screws, just loosen them . The fan schroud is notched for these as locators. The top two will have to come out, if I remember correctly and they are pretty long 1" self tapping type. Try not to break the dipstick handle. Good luck
- Has thanked: 1611 times
- Been thanked: 4075 times
GlennG2759 wrote: 17 May 2019, 19:23 I don't think you'll have to take out the bottom two torq screws, just loosen them . The fan schroud is notched for these as locators. The top two will have to come out, if I remember correctly and they are pretty long 1" self tapping type. Try not to break the dipstick handle. Good luck
+1000 points of the fasteners and remove the dipstick too!
- 1029 Views
Last post by shiloh51933
- 22 Replies
- 2518 Views
Last post by polskamafia mjl
- 745 Views
Last post by tryingbe
- 485 Views
Last post by JimBee
- 1214 Views
