Acts like it’s not getting gas starts then dies
Nate1227
Year and Model: 2001
Post by Nate1227 »
I have a 01 Volvo v70 xc and it’s actling like it’s not getting any gas even with the pedal all the way to the floor. When it finally starts it sputters and when put in gear it jerks.
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
01's had problems with the throttle body. The sensor strips would wear and then the engine computer could not determine the throttle position. Might not be your problem.
What mileage on your car? Any check engine light? Any codes stored?
Do you have the Torque App and a bluetooth ODB2 reader, or Volvo DICE?
rudsaki
Year and Model: 1998 S70 T5
Has thanked: 29 times
Been thanked: 16 times
Post by rudsaki »
Sounds like internal fuel pump. Also like my 04 there is a tank rollover safety feature that goes bad and I cannot access the last 3 gallons of gas
Previous Volvos
1969 142s Blue manual.
1966 122s Yellow with the 69 motor in it
1971 144s Red . Also the '69's motor
1973 P1800ES Aqua Manual with OD.
1971 142E Light Blue manual with OD.
1979 244DL Brown manual. Marriage/baby car. Divorce, Ex got it and sold it to my father!
1968 1800s White manual/OD. Strong runner. Killed by a '66 T-Bird
1984 242 Turbo Intercooler Silver Manual/OD
1966 1800s White Manual/OD
1985 740 Turbo Intercooler Silver Manual/OD Sold to Nephew
Nate1227
Post by Nate1227 »
EngineeringBloke wrote: 18 May 2019, 21:43 01's had problems with the throttle body. The sensor strips would wear and then the engine computer could not determine the throttle position. Might not be your problem.
It has 150 thousand the light came on and was reset and hasn’t came back on. It read cam sensor. Also catalytic converter clogged
EngineeringBloke
If the throttle was involved, I would expect a code for it, so probably not your issue.
If the exhaust is blocked then the car won't run.
So you still have the issue but no check engine light or stored codes?
