IPD sale Volvo Parts
Did you know? 🤔
Acts like it’s not getting gas starts then dies
2001 - 2007 XC-70
Nate1227
Year and Model: 2001
Has thanked: 0
Been thanked: 0
United States of America
Nate1227
Post by Nate1227 » Sat May 18, 2019 6:41 am
I have a 01 Volvo v70 xc and it’s actling like it’s not getting any gas even with the pedal all the way to the floor. When it finally starts it sputters and when put in gear it jerks.
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 28 times
Been thanked: 19 times
EngineeringBloke
Re: Acts like it’s not getting gas starts then dies
Post by EngineeringBloke » Sat May 18, 2019 9:43 pm
01's had problems with the throttle body. The sensor strips would wear and then the engine computer could not determine the throttle position. Might not be your problem.
What mileage on your car? Any check engine light? Any codes stored?
Do you have the Torque App and a bluetooth ODB2 reader, or Volvo DICE?
rudsaki
Year and Model: 2004 S60 AWD
Has thanked: 3 times
Been thanked: 0
rudsaki
Post by rudsaki » Sun May 19, 2019 9:51 am
Sounds like internal fuel pump. Also like my 04 there is a tank rollover safety feature that goes bad and I cannot access the last 3 gallons of gas
Nate1227
Has thanked: 0
Been thanked: 0
Nate1227
Post by Nate1227 » Sun May 19, 2019 8:39 pm
It has 150 thousand the light came on and was reset and hasn’t came back on. It read cam sensor. Also catalytic converter clogged
EngineeringBloke
EngineeringBloke
Post by EngineeringBloke » Mon May 20, 2019 8:41 am
If the throttle was involved, I would expect a code for it, so probably not your issue.
If the exhaust is blocked then the car won't run.
So you still have the issue but no check engine light or stored codes?
