IPD sale Volvo Parts
Did you know? 🤔
Tensioner Pulley...
2001 - 2007 XC-70
rotteko
Year and Model: 2002 V70 XC
Has thanked: 0
Been thanked: 0
United States of America
rotteko
Tensioner Pulley...
Post by rotteko » Sun May 19, 2019 10:03 am
Greetings:
My tensioner pulley seized up yesterday and the serpentine belt broke. I have been trying to find a replacement pulley, however, all of the pulleys I find online, or at parts stores are different than what I have on the vehicle. Did Volvo change the design at some point? The existing pulley is small and somewhat ribbed. Where would I find this pulley, or should I replace it with a newer style?
Also, I have had the belt off before and it has always been very difficult to put back on, it seems that if I put a larger tensioner pulley, I would need a longer belt. Is that accurate?
Thanks
June
Year and Model: 2004 S80 T6
Has thanked: 199 times
Been thanked: 97 times
June
Re: Tensioner Pulley...
Post by June » Sun May 19, 2019 10:35 am
Your pulley is gone! Every Volvo I have had has had the same diameter (or extremely close) pulley. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
June
June
Post by June » Sun May 19, 2019 10:44 am
Here is the Blue Box Genuine Volvo installed by my dealer tensioner and pulley. If belt wrapped around the balancer check timing belt before starting. June
My Volvo cars owned
1996 960 ordered
rotteko
Has thanked: 0
Been thanked: 0
rotteko
Post by rotteko » Sun May 19, 2019 11:08 am
That explains a lot. Thanks for the help...
oragex
Year and Model: S60 2003
Has thanked: 79 times
Been thanked: 168 times
Canada
oragex
Post by oragex » Sun May 19, 2019 11:35 am
As mentioned above, it would be good to make sure the belt didn't jump a tooth or so - may check the timing marks
There are two types of tentioners which are different www.youtube.com/watch?v=Yd5gHFnHaYk
I recommend as above getting a genuine Volvo one for this part, I've had troubles setting aftermarket tensioners with their temp needle. Can get parts from Fcpeuro.com but 2x check to get the one for your engine serial number (the sticker on the timing belt cover on stamped behind the engine block) https://www.fcpeuro.com/Volvo-parts/S60 ... Tensioner/
There are a few Youtube videos if your have trouble setting the tensioner. Also careful with the center bolt torque, 15lb*ft
The timing belt should run without waving and in the center of the cam gears when the tensioner is set right
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
Has thanked: 0
Been thanked: 75 times
Post by cn90 » Sun May 19, 2019 12:02 pm
I posted the info on serp belt in the 2005 XC90 2.5T TB, SB job:
https://www.matthewsvolvosite.com/forum ... 10&t=83521
You will need:
1. To verify when your TB was last changed etc.
2. New SB: Conti
3. Tensioner Pulley, ideally INA including the tensioner itself. Or you can just replace the pulley only,
4. Idler Pulley: INA>
June
June
Post by June » Sun May 19, 2019 4:27 pm
Let us know the outcome please. June
My Volvo cars owned
1996 960 ordered
