Making the stereo work with the key in the off position...
wrybread
Year and Model: 1998 S70 GLT
Has thanked: 15 times
Been thanked: 15 times
Post by wrybread »
I like to set up my car stereo so I can use it even with the car off, and ideally so the cigarette lighter socket can deliver power too, so I can leave my phone charging. I usually just hook up a switch between the constant 12v+ and the switched 12v+ in the stereo harness, but I did that just now with my SC-816 and blew two fuses...
Can anyone think of a reason for that, other than user error?
I verified the wires with my multimeter and all looked good. No power to the switched line until I turned the key. Other line had power always.
And this diagram agrees with my wire choices:
https://www.tehnomagazin.com/Auto-radio ... nector.htm
Connecting one of the green/brown wires (constant 12v+) to yellow/purple (switched 12v+). In this diagram that's wire 1 and 3.
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Instead of an SPST switch, use an SPDT.
Connect the common contact to the radio
ign and the batt and harness ign to the two
switched contacts of the switch.
That way, the ign lead from the harness is
disconnected from power when you flip to
batt and there’s no backfeed up the harness.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Or install a diode and it will just always have power and never backfeed =)
wrybread
Post by wrybread »
That's a good idea. Any recommendation on which diode by chance?
wizechatmgr
My thought is one of these on each power line (aka V1,V2) going towards the radio should do it... They are basically one way valves for electricity.
pardon the garbage schematic no guarantee I have the cathode anode correct, it's just here for purposes of clarity
https://www.amazon.com/RUITASA-Schottky ... 4253919969
Has thanked: 1610 times
Been thanked: 4068 times
The diode needs to be rated for the expected power draw if about 10 watts for the charger, plus 50% margin
wizechatmgr
abscate wrote: 26 May 2019, 01:44 The diode needs to be rated for the expected power draw if about 10 watts for the charger, plus 50% margin
Absolutely...
These are rated for 10 amps each. Worst case scenario he uses two or three in parallel for each voltage source.
wrybread
Post by wrybread »
Great ideas, will try next week.
I still don't get why bridging two circuits would cause a short or a power draw. I was working by headlamp after a long day so maybe I did something stupid. My plan is to insert two 5a fuses and connect the two lines with a multimeter set on current measurement to see if I see the same power draw.
If it blows that again, plan diode.
