IPD sale Volvo Parts
Did you know? 🤔
Engine System Service Required
2001 - 2007 XC-70
michaelunderway
Year and Model: 2000 v70xc
Has thanked: 2 times
Been thanked: 0
United States of America
michaelunderway
Post by michaelunderway » Fri May 24, 2019 6:46 am
I drive a 2001 V70XC with about 175k miles on it. I generally do all the maintenance and repairs myself. A few days ago had the engine system service required light come on and I can't get it to go away. I have tried the odometer button reset that generally works. My closes Volvo dealer is almost 2hours away through the mountains. This weekend I plan on pulling the ETM and cleaning it, swapping out the brake position switch with a known good one and changing the fuel filter. Does anyone have any other suggestions on what I can start looking at? It seems to run well, has no DTC codes. The spark plugs are only a year old. What else would cause this light to stay on? Thanks in advance.
ndphotonl
Year and Model: S80 2.4T Wasa
Has thanked: 16 times
Been thanked: 19 times
Netherlands
ndphotonl
Re: Engine System Service Required
Post by ndphotonl » Fri May 24, 2019 7:07 am
Dont know, but you are able to reset it using Vida. If your dealer is 2 hours away, I would suggest to invest in a DICE unit
Volvo S80 2.4T Wasa Limited Edition
Blog / FlickR / YouTube channel
michaelunderway
Been thanked: 0
michaelunderway
Post by michaelunderway » Fri May 24, 2019 7:37 am
I own 3 Volvos so I do plan on getting Vida/Dice unit when I have the funds. But for now I just want to make sure the car runs safely until I get one. Thanks
Has thanked: 189 times
Been thanked: 601 times
Trinidad & Tobago
Post by abscate » Fri May 24, 2019 11:03 am
If it is running well and not misfiring, it can probably wait until you can get a code reader on it. If you have a auto parts store nearby, then can read codes for you - get the Pxxxx format code, not the text reader word salad.
michaelunderway
Been thanked: 0
michaelunderway
Post by michaelunderway » Fri May 24, 2019 11:13 am
I have multiple obd readers but they wont pull codes because non are stored.
Trinidad & Tobago
Post by abscate » Fri May 24, 2019 5:01 pm
The cheap ones won't read the more complex codes.
Unless the message is the service interval message, not the service required message?
Check your manual for the difference (those are online if you have lost yours)
Year and Model: Lots
Has thanked: 4 times
Been thanked: 94 times
Australia
Post by precopster » Sat May 25, 2019 7:01 am
The odometer reset is the SRL or service reminder light.
This one is a fault in one of the car's emission systems. It can be a sensor or throttle that has operated outside of expected values.
Any code reader will perform a reset of the DTC (diagnostic trouble code) including Torque through an ELM327 , though there are some instances that it can't handle and that's when I pull out my Autel AL619 or Vida Dice.
Has the reset menu through your OBD readers failed to temporarily clear that message?
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
michaelunderway
Been thanked: 0
michaelunderway
Post by michaelunderway » Sat May 25, 2019 7:21 am
If my OBD readers clear the message it comes right back. I may have to wait until I get a Vida/Dice setup. Thanks
