Hello,
After replacing my wheel hubs on both front wheels I now have a low tone noise coming from the right that turns into a high pitched noise when I take a very hard turn to the left.
Any ideas ?
Thanks for your help !
Front Right side noise after wheel hub replacement OBQ SKF BEARING!) Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
From that description it sounds like a bad hub bearing on the right. What's the bearing source?
Did you check and make sure nothing is stuck, for example behind the brake pads?
Hmmmm also are you sure the axle is seated all the way in the hub? Though you never know of course, SKF should be good.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
A swap may help diagnose OR clear the issue. Wheel alignment is a good idea.
- Fiodor
- Year and Model: 1997 V70 2.0 T5 AWD
- Has thanked: 13 times
- Been thanked: 9 times
Well it sure took a hell of a time but it eventually got fixed.
It was a bad wheel hub out of the box...
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
Obq is industry speak for out of box quality
- 29 Replies
- 15338 Views
Last post by erikv11
- 191 Views
- 2391 Views
Last post by [email protected]
- 1095 Views
Last post by kjhiggins
- 3428 Views
Last post by BlackBart
