Hey Guys, i have a simple question. I have a 2000 s70 2.4 non turbo and my steering rack is leaking and i was wondering what type of power steering fluid to use while its still leaking? do i need to use expensive stuff or just regular fluid ?
appreciate any help
Thanks Jim
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
It will either solve your problem for a while, or tell you you need a new steering rack. Recommend ATP-205.solidwood wrote: 26 May 2019, 13:39 Thanks I appreciate it but what happens if it doesn't work does it do any damage
Knows enough to be dangerous
- Has thanked: 312 times
- Been thanked: 818 times
A 2000 came from the factory with Pentosin PS fluid. You can use Pentosin or ATF, either one of those works well, but you do not want to mix them. The Pentosin is greenish, ATF is read.
If you don't know what fluid the system has then I would probably remove as much as possible with a turkey baster, then refill it, run it for a 10 minutes with lots of turning the wheel then flush it one more time, so you know exactly what is in there. Capacity is small like 20 oz. My preference is ATF, DexIII works great.
As a rule I stay far, far away from snake oil in a can solutions, but ATP AT-205 has been very successful for people on this forum, in several places including PS. You could use that with Pentosin. For PS leaks, Valvoline MaxLife ATF is another one worth trying, people here have had good success with that too.
- MoVolvos
- Been thanked: 525 times
I was thinking about introducing the ATP-205 but wasn't sure if it would be considered snake oil on the forum. I recently purchased 6 bottles after a seeing Scotty Kilmer's video suggesting its use. So far I've put it in a 03 Odyssey PS Pump as it has been ever so slowly seeping at the hose for a couple of years.erikv11 wrote: 27 May 2019, 20:22
There is also a wet drip that never comes down on the driveway on the 03 S80 T6. Not sure if it has always been there before I did the Filter Change, Trans-Flush and Transgo Shift Kit on the Volvo GM transmission. One poster said it could be a Torque Converter seal so I thought I give it a try. Just wipe that never drip fluid off today and will report back if it is gone due to the ATP-205.
- 30 Replies
- 27501 Views
- 6186 Views
Last post by EngineeringBloke
- 1874 Views
Last post by Shift727
- 11 Replies
- 2213 Views
- 1178 Views
Last post by PS78
