IPD sale Volvo Parts
Did you know? 🤔
Replacing A/C Compressor
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
volvooh
Year and Model: '98 S70, '05&'08 V70
Has thanked: 0
United States of America
volvooh
Post by volvooh » Wed May 29, 2019 5:52 am
2008 Volvo V70, 156,xxx mi. I purchased the vehicle knowing I would need to replace the compressor, makes a noise that sounds like rattling spoons. How is the serpentine belt relaxed to facilitate removal? Also, where is the A/C dryer located? Makes sense to replace this as well if I am going to the effort of the compressor.
Has thanked: 190 times
Been thanked: 601 times
Trinidad & Tobago
Re: Replacing A/C Compressor
Post by abscate » Wed May 29, 2019 8:13 am
Not an expert on the 2008s but I expect the drier is mounted on the condenser like the P2s - unlike the P80s with the big coffee can near the frame member. Look for an aluminum soda can size thing or a skinny tube thing near the condenser?
Screen Shot 2019-05-29 at 10.18.08 AM.png (201.46 KiB) Viewed 152 times
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 11 times
Been thanked: 18 times
pgill
Post by pgill » Wed Jul 03, 2019 2:57 pm
Volvooh,
For my 2010 S80 3.2 the dryer is a desiccant bag inside the condenser.
It comes in a sealed aluminium Mylar bag and it only has a 1 year shelf life.
Don't open the Mylar Bag until you are ready to install the desiccant in the condenser.
The cap that holds the bag in place uses a Torx T-70 fastener.
I didn't check but I would think that the V70 uses the same configuration
This is what I bought
GENUINE VOLVO 30776238 Receiver Drier Insert
If I had to do it again I would also replace the plastic cap witht he O-rings and filter screen at the same time (I don't have the part number handy)
Note: to replace the desiccant bag you need to lift the radiator and Fan and then lower the cross-member under the radiator. This will expose the plastic cap with the T-70 that needs to be removed. Also don't forget to remove the R134a first.
Good Luck
Paul
P.S. I ended up replacing the AC compressor also and now it blows really cold
pgill
pgill
Post by pgill » Wed Jul 03, 2019 3:02 pm
Item #2 and #3
These are what I would replace
To remove the old bag you just need needle nose pliers or small fingers
The Bag fits inside the condenser, picture not to scale.
