99' S70, 5-speed, surging idle
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Hi folks,
I've been driving the new to me S70 around and it has an idle problem.
When I come to a stop and take it out of gear the idle starts surging and sometimes the engine cuts out.
From doing a little research on here this may be pointing to a bad ETM. The ETM is a yellow label unit and the car has 209k on it now. I was hoping this would last a little longer but maybe not.
Would you guys agree or is there something else I should be looking at first?
Thanks, Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
krenekj
Year and Model: Wife says too many
Has thanked: 2 times
Post by krenekj »
When I suspected ETM issues, XmodeX was a great resource. They had a good flow chart one could follow to diagnose a failing ETM:
ETM Diagnostic Flow Chart.pdf
(142.07 KiB) Downloaded 195 times
Their techs are also very responsive to submitted questions and calls. That may have changed now that they only sell through authorized resellers, but it's worth a try.
https://xemodex.com/us/
Of course there are other issues that affect your idle, but if you suspect a ETM, they are a good resource to get better clarity on the ETM's functionality and impact to your issue.
Thanks.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
850 LPT
Post by 850 LPT »
krenekj wrote: 31 May 2019, 11:41 Of course there are other issues that affect your idle
I would like to learn more about this.
That flow chart looks to be very helpful.
I was just poking around their website and it looks like one could order from them directly again?
They suggest to replace the MAF along with the ETM. I don't know but that is getting pricey.
I need to drive the car more to complete the drive cycles and see what lights come on.
The battery went dead on me while I was working on the car and I am just now starting to drive it more regularily.
Thanks, Dirk
Has thanked: 1609 times
Been thanked: 4065 times
Dirk, that 99 NA has an idle air valve like a 1998. Denso ingnition and air/ fuel management.
Give that a clean , then let’s look at fuel trims
At under 200k, leave the ETM alone for now
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Could also try running it without the MAF connected I believe. Typically if performance improves it's a sign the MAF "might" be going bad.
850 LPT
Post by 850 LPT »
Thanks guys, I will investigate that idle control valve and clean if I can find it. Interesting about disconnecting the MAF, will try that too.
850 LPT wrote: 31 May 2019, 18:22 Thanks guys, I will investigate that idle control valve and clean if I can find it. Interesting about disconnecting the MAF, will try that too.
Comes off the snorkel aft of the throttle body. Dumps air into the intake manifold by a long hose.
