Hi Folks
I moved the crank pulley trying to remove it when I thought I had to do so when changing the timing belt: well, I worked out I didn’t have to so put it back on the mark and put the new belt on. All the marks line up and I’ve turned the engine over with a ratchet. Seems okay. Probably a dumb question but d could I have screwed up the timing even if the marks are okay?
Cheers!
Moved the crankshaft pulley
- Been thanked: 4064 times
You are okay of the marks line up, not To worry
- 1404 Views
Last post by DGB47
- 1001 Views
Last post by marcus
- 2713 Views
Last post by Williamad33
- 2562 Views
Last post by oragex
- 446 Views
