Hi All
I just changed the timing belt and water pump; started her up and the pump is leaking like a sieve. Obviously I didn't clean up the block good enough - there was some corrosion from the old pump. Anyone have any suggestions as to the best way to make sure the new pump will seat okay? How about using a very fine emery cloth to shine things up? I've ordered another gasket...
Water Pump Leaking
Archer
- Year and Model: 2002 V70/S60 T5
- Been thanked: 5 times
Same thing happened to me, so annoying having to back-track. Anyhow, turned out to be a bit of the old gasket material on the block. Emery cloth sounds like a good idea...on the second attempt I used Permatex water pump & thermostat housing silicone rtv on the new gasket (thin coat) and under side of the bolt heads.
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
it would not prevent leak from a major misalignment, and if ever replaced again (doubtful since each pump is good for two belt changes) its hard to clean up the rtv in the close space.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
RTV for coolant, it's a special one. Put just enough so it doesn't leak inside when positioning the pump. Smear a little on both sides of the gasket. Hope that is an Aisin pump right ? About the only safe brand (or genuine)
A razor blade to remove big chunks of old gasket, then a Stainless Steel Wire Sponge to finish the surface - doesn't scratch and it's tough enough for those limestone deposits. Be sure to tighten down the right torque - it's not a lot, too much will crush the gasket too much https://blog.fcpeuro.com/replacing-the- ... lvo-s60-t5
- DeadEric
- Year and Model: 1996 850 Turbo
- Has thanked: 2 times
- Been thanked: 12 times
If I use rtv, it's only on the pump side of the gasket to keep it in place during install. Keeps you from having to clean it from the block next time.
You can add coolant after the pump is installed before the belt is on. It should leak, if you have one, as the air will have a place to escape. I usually install the pump, clean the mess, fill the coolant till it won't take more then have a lunch or something. Check for leaks or drips when you're back.
You might be able to rent a coolant pressure tester from the auto parts store. They pressurize the system with an air pump and have a gauge to measure psi. Just make sure they have the fitting for your Volvo and don't use more pressure than your system does.
A nylon brush and some CLR isn't a bad idea for the block side. Might take more time than other methods but the cleaner the better.
- SuperHerman
- Been thanked: 207 times
Just clean the surface up well and make sure it is flat. The gasket will take care of most "normal" imperfections. I have never used RTV when it wasn't required. Many do it for good measure - that is your call. Just make sure the "squish" does not get into the coolant system.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
As Herman noted RTV isn't needed for the water pump gasket. When I installed the water pump earlier this year I just put a tab of silicone grease on the gasket to hold it in place. I scrubbed off the OEM gasket using brake cleaner on emery cloth. As mentioned cleaning up the RTV will be a hassle.
- 455 Views
- 5139 Views
Last post by kallekula
- 1423 Views
Last post by e777
- 243 Views
Last post by pinegrovedave
- 3655 Views
