IPD sale Volvo Parts
Did you know? 🤔
[2001 V70 2.4T] Low coolant, high coolant temp, no cooling fan Topic is solved
2001 - 2007 XC-70
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 4 times
Been thanked: 20 times
United States of America
prwood
Post by prwood » Tue Jun 04, 2019 11:36 am
Today on my way to work I got the "low coolant / stop asap" message on the DIM. I pulled over, opened the coolant reservoir cap, and found that the level was down to the bottom of the reservoir. There were also signs that the coolant had boiled over (steam, fluid splashed around the reservoir. No signs of leakage from any coolant lines.
I topped off the coolant and started the engine again with the reservoir cap off. On my OBD scanner I saw that the ECT was reported as 212F which is pretty high for my engine. I also noticed that the engine cooling fan wasn't running. I turned the climate control system to heat and set the blower fan to max, and within a few minutes the ECT reading had dropped to ~195F, pretty normal for my engine.
My assumption is that the cooling fan isn't running, preventing the radiator from properly cooling the system. This has happened a few times before, for the following reasons:
- ECT sensor disconnected or malfunctioning
- Cooling fan control wire disconnected or severed
In this case, however, I feel that the ECT sensor reading is good, based on my observations above. I also verified that the cooling fan control wire was connected. I back-probed the control wire on the wiring harness side of the connector and it read ~13.3V, which seems correct for if the ECM is calling for the cooling fan to activate. I also checked the voltage at the cooling fan power connector and it also read ~13.3V. I checked the fuse that handles the cooling fan and it registered ~13.3V on both sides. I checked the fan blades themselves and there wasn't anything obstructing me from turning them manually.
At this point it seems like the problem must be somewhere between the cooling fan power and signal connectors and the fan motor. I haven't yet checked for DTCs in VIDA but could do that. Any suggestions what to check next? Fan controller, motor, or wiring?
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T
Has thanked: 188 times
Been thanked: 600 times
Trinidad & Tobago
Re: [2001 V70 2.4T] Low coolant, high coolant temp, no cooling fan
Post by abscate » Tue Jun 04, 2019 7:47 pm
Coolant temps between 87-105C are totally normal. At about 105-110C the fan should kick on, though.
I did a documentation on this sitting in the Nexus line at the Canadian border in my T5
oragex
Year and Model: S60 2003
Has thanked: 79 times
Been thanked: 167 times
Canada
oragex
Post by oragex » Wed Jun 05, 2019 1:53 am
As abscate, nothing to worry (220F - about 105C). The thermostat is fully open at 95C but the fan kicks in quite much later.
I'd try a used reservoir cap, and also see if the small return hose at the reservoir is tight enough- this little clamp can get weak and let pressure escape
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
Trinidad & Tobago
Post by abscate » Wed Jun 05, 2019 3:35 am
Peter. Put your AC high, full cool and I think that’s should activate and confirm your fan is working.
Used from a pick And pull is best source
prwood
prwood
Re: [2001 V70 2.4T] Low coolant, high coolant temp, no cooling fan  Topic is solved
Post by prwood » Wed Jun 05, 2019 8:03 am
Aaaaaand it turns out it was the fan signal getting severed. Again.
Last time I did a quick fix with a wire nut.
This time I spliced and soldered it back together properly.
Cars I've owned:
Trinidad & Tobago
Post by abscate » Wed Jun 05, 2019 3:35 pm
:oops: :oops: :oops:
My late father (Saturn V, LEM, Shuttle, Concorde)
There is always enough time to do the job again, correctly.
prwood
prwood
Post by prwood » Wed Jun 05, 2019 3:40 pm
Hopefully he would be proud of my splice job, done to NASA standards:
Cars I've owned:
