Has anyone changed the serpentine belt on the 3.2 engine? I'm having to replace the AC compressor and the belt has some cracks. I'm also replacing the idler and tensioner pulleys while I've got it apart.
The belt is a bear to replace. The power steering pump has to come off to change it. I'm almost there but there is one last bolt that I can see, but can't reach because of the lines from the ABS unit. I've tried extensions and universal joints, but still can't get on it to turn it.
Has anyone done this and if so any suggestions? There is precious little information in the way of drawings and videos that I have been able to find. Lot's of stuff for the 2.5 engines, but almost nothing on the 3.2.
Thanks.
2009 XC90 3.2 Serpentine belt
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
woodg
- Year and Model: 2006 S60 T5
- Has thanked: 1 time
Thanks. I had seen that one, but it appears that the Land Rover has the ABS in a different place. I'll upload some pics later to show you what I'm talking about.
My 3 month old grandson could reach the bolt that I'm having trouble with if he could turn it, but normal adult human beings will have a tough time fitting through the openings or bending in the right places to reach the last bolt.....lol. Then there will be the issue of getting the bolt back in.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
2001 S80 T6 Exec
2009 XC90 3.2
wanderdüne
Here: https://workshop-manuals.com/volvo/xc90 ... age_17771/
it says to remove the two bottom bolts on the ABS bracket, then loosen the center bolt in the middle (on the next page) not more than 4 turns. Maybe there's enough movement of the ABS unit to get clearance to the ps pump bolt?
One tip I have for threading a bolt back in a tight space is to put a little square of tissue paper over the open end of the socket, then push the bolt head in. It holds pretty good.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
This is for the LR2 also but it has a lot of useful tips
http://www.freel2.com/forum/topic33363.html
When you put everything back together the spring that runs the water pump needs to get inserted back into the correct location
Green Arrows
One end of the spring will interface with the plastic bracket at the one of the upper green arrows
The opposite end of the spring will interface with the water pump in the hole shown by the lower green arrow
If you are not careful the spring will end up by the red arrow location and it will make an annoying clicking sound
Green Arrows
woodg
Good thought, but not near enough room to get to the bolt. My next step is to remove the LF wheel and see if I can get to it from there.wanderdüne wrote: 05 Jun 2019, 09:42 Here: https://workshop-manuals.com/volvo/xc90 ... age_17771/
Here are a couple of pictures.
Not pretty but I think you get the idea.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
2001 S80 T6 Exec
2009 XC90 3.2
31years
- Year and Model: 2009 XC90
FYI, here's the best write-up on Serpentine belt that I've found:
viewtopic.php?f=10&t=82356&p=447247&hil ... mp#p447247
- 11180 Views
Last post by pgill
- 20 Replies
- 17683 Views
Last post by Hurtfeelings
- 22 Replies
- 36101 Views
Last post by erikv11
- 21 Replies
- 5383 Views
Last post by viper69
- 62 Replies
- 17970 Views
Last post by Shanestrait
