2009 XC90 3.2 Serpentine belt
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
woodg
Year and Model: 2006 S60 T5
Post by woodg »
Has anyone changed the serpentine belt on the 3.2 engine? I'm having to replace the AC compressor and the belt has some cracks. I'm also replacing the idler and tensioner pulleys while I've got it apart.
The belt is a bear to replace. The power steering pump has to come off to change it. I'm almost there but there is one last bolt that I can see, but can't reach because of the lines from the ABS unit. I've tried extensions and universal joints, but still can't get on it to turn it.
Has anyone done this and if so any suggestions? There is precious little information in the way of drawings and videos that I have been able to find. Lot's of stuff for the 2.5 engines, but almost nothing on the 3.2.
Thanks.
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Been thanked: 40 times
Re: 2009 XC90 3.2 Serpentine belt
Post by wanderdüne »
Looks painful: viewtopic.php?t=85369
This may help some, it's on a Landrover that uses the engine:
woodg
Post by woodg »
Thanks. I had seen that one, but it appears that the Land Rover has the ABS in a different place. I'll upload some pics later to show you what I'm talking about.
My 3 month old grandson could reach the bolt that I'm having trouble with if he could turn it, but normal adult human beings will have a tough time fitting through the openings or bending in the right places to reach the last bolt.....lol. Then there will be the issue of getting the bolt back in.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
wanderdüne
Here: https://workshop-manuals.com/volvo/xc90 ... age_17771/
it says to remove the two bottom bolts on the ABS bracket, then loosen the center bolt in the middle (on the next page) not more than 4 turns. Maybe there's enough movement of the ABS unit to get clearance to the ps pump bolt?
One tip I have for threading a bolt back in a tight space is to put a little square of tissue paper over the open end of the socket, then push the bolt head in. It holds pretty good.
woodg
Post by woodg »
Thanks, that may give me what I need.
I'll let you know.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 25 times
Been thanked: 45 times
Post by pgill »
This is for the LR2 also but it has a lot of useful tips
http://www.freel2.com/forum/topic33363.html
When you put everything back together the spring that runs the water pump needs to get inserted back into the correct location
Green Arrows
One end of the spring will interface with the plastic bracket at the one of the upper green arrows
The opposite end of the spring will interface with the water pump in the hole shown by the lower green arrow
If you are not careful the spring will end up by the red arrow location and it will make an annoying clicking sound
woodg
Post by woodg »
Thanks for the heads up.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
woodg
Post by woodg »
wanderdüne wrote: Wed Jun 05, 2019 9:42 am Here: https://workshop-manuals.com/volvo/xc90 ... age_17771/
Good thought, but not near enough room to get to the bolt. My next step is to remove the LF wheel and see if I can get to it from there.
Here are a couple of pictures.
Not pretty but I think you get the idea.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
31years
Year and Model: 2009 XC90
Post by 31years »
FYI, here's the best write-up on Serpentine belt that I've found:
viewtopic.php?f=10&t=82356&p=447247&hil ... mp#p447247
Tsluder
Year and Model: 2008 XC90
Post by Tsluder »
On FCP euro YouTube video, he removed the wheel on the sedan to make serpentine belt easier to install. Google the tutorial “ Volvo serpentine belt install FCP EURO”
