Amazon Black Friday deals
2009 XC90 3.2 Serpentine belt
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
31years
Year and Model: 2009 XC90
Re: 2009 XC90 3.2 Serpentine belt
Post by 31years »
Tsluder wrote: Mon Nov 04, 2019 9:05 am On FCP euro YouTube video, he removed the wheel on the sedan to make serpentine belt easier to install. Google the tutorial “ Volvo serpentine belt install FCP EURO”
Unfortunately for XC90 3.2 owners, that engine compartment layout is totally different.
Tsluder
Year and Model: 2008 XC90
Post by Tsluder »
Oh I agree. What I was meaning is that removing the wheel to gain access to remove and install the serpentine belt on the xc90 maybe the same process.
jerryv
Year and Model: 2007 XC90 3.2
Has thanked: 3 times
Post by jerryv »
@woodg
How did you end up accomplishing this? I'm stuck trying to get that last bolt off the power steering bracket....so frustrating!
jerryv
Post by jerryv »
Update: After much hassle, I finally got the bolt out with a 1/4 drive ratchet 10mm socket and secret blend of 11 herbs and spices to get the length just right.
Turbo_Boss
Year and Model: 2008 XC90 3.2AWD
Has thanked: 9 times
Post by Turbo_Boss »
Hey Guys
I replaced my serpentine belt a few weeks ago and I follow this tread: https://www.freel2.com/forum/topic33363.html
I recomend you to read that tread. I also write there some advises with some photos
We use a joint Swivel Socket Adapter with a long extension to remove one of the screws that hold the power steering pump. This screw is located in the fire wall side and is almost impossible to see this screw…… You have to put your hand there and fill it with your fingers, connect the socket and hold it there while somebody with a long extension ratchet it to remove or tighter it.
Good luck
Isaac
2008 VOLVO XC90 3.2L AWD
2008 TOYOTA Prado 2.7L 4x4
2009 VW Jetta 2.0
jerryv
Post by jerryv »
Excellent write up Turbo_Boss. Much better than the instructions I was following and will no doubt help a lot of people.
For anyone in the future: In was able to reach under the ABS and turn a 1/4 ratchet with enough extension to clear the transmission shift cable to break the PS bolt. If your particular bolt is better behaved, a 10mm 6-point ratcheting stubby wrench would probably get the job done.
