Unfortunately for XC90 3.2 owners, that engine compartment layout is totally different.
2009 XC90 3.2 Serpentine belt
- Year and Model: 2009 XC90
Re: 2009 XC90 3.2 Serpentine belt
- Year and Model: 2008 XC90
Oh I agree. What I was meaning is that removing the wheel to gain access to remove and install the serpentine belt on the xc90 maybe the same process.
- Year and Model: 2007 XC90 3.2
- Has thanked: 3 times
- Been thanked: 2 times
@woodg
How did you end up accomplishing this? I'm stuck trying to get that last bolt off the power steering bracket....so frustrating!
Update: After much hassle, I finally got the bolt out with a 1/4 drive ratchet 10mm socket and secret blend of 11 herbs and spices to get the length just right.
- Year and Model: 2008 XC90 3.2AWD
- Has thanked: 9 times
Hey Guys
I replaced my serpentine belt a few weeks ago and I follow this tread: https://www.freel2.com/forum/topic33363.html
I recomend you to read that tread. I also write there some advises with some photos
We use a joint Swivel Socket Adapter with a long extension to remove one of the screws that hold the power steering pump. This screw is located in the fire wall side and is almost impossible to see this screw…… You have to put your hand there and fill it with your fingers, connect the socket and hold it there while somebody with a long extension ratchet it to remove or tighter it.
Good luck
Isaac
Good luck
Isaac
2008 VOLVO XC90 3.2L AWD
2008 TOYOTA Prado 2.7L 4x4
2009 VW Jetta 2.0
2009 VW Jetta 2.0
Excellent write up Turbo_Boss. Much better than the instructions I was following and will no doubt help a lot of people.
For anyone in the future: In was able to reach under the ABS and turn a 1/4 ratchet with enough extension to clear the transmission shift cable to break the PS bolt. If your particular bolt is better behaved, a 10mm 6-point ratcheting stubby wrench would probably get the job done.
- 5386 Views
Last post by pgill
- 10 Replies
- 10313 Views
Last post by chitownV
- 322 Views
Last post by 2000c70hpt
- 18 Replies
- 6612 Views
Last post by Dllambe
- 62 Replies
- 2793 Views
Last post by Shanestrait
