Since I am not even sure of where the ATF line actually is, can anyone tell me what the I.D. is on my 2002 V70 so I can purchase the correct size filter?
Here is the e-mail response from the "Magnefine" company: "It will either have a 3/8" or 1/2" I.D. You will be able to tell if it is the 1/2" as the OD of the line is extremely large. Most of the Volvo's in that era are the 3/8" but there were some that were the 1/2" so I don't want to guess."
ATF line I.D. for Magnefine filter?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
In late April I defined the size of the Magnefine filter. I found it in a few seconds using the SEARCH function
Watch these video in this post I made for you in your 'Crush Washer' thread. It defines how to install the filter, drain the ATF, shows the location of the ATF drain plug and answers many more questionsXC70Rider wrote: 21 Apr 2019, 07:18
The Magnefine 3/8" Magnetic Inline Transmission Filter does have an internal bypass valve. Measuring the ATF temp with VIDA the temp didn't change after I installed this filter last December. I wouldn't of installed the filter if it didn't have the bypass valve.
Mr. Detail
Thanks much gentlemen!
- 1819 Views
Last post by tom4342
- 1343 Views
Last post by vtl
- 1259 Views
Last post by moncureww
- 11 Replies
- 11693 Views
Last post by STSCowboy
- 1011 Views
Last post by 01_Nautic_V70
