Did you know? 🤔
Can I put the B5254T motor into my XC90 that originally came with a B5254T2?
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
RickHaleParker
Has thanked: 3 times
Been thanked: 560 times
United States of America
RickHaleParker
Re: Can I put the B5254T motor into my XC90 that originally came with a B5254T2?
Post by RickHaleParker » Thu Oct 10, 2019 11:27 pm
3kgtaddict213 wrote:
Thu Oct 10, 2019 7:24 pm
So once I pull the camshaft position sensor how would I be able to tell if they're aligned properly or not?
1. The two slots, one each camshaft should be horizontal (3:00 to 9:00).
2. The slots are off center. Intake should be above center and exhaust below center.
Else, you could install the camshaft alignment tool on the rear end, then get the three marks on the front aligned.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
3kgtaddict213
Year and Model: 2006 XC90
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Fri Oct 11, 2019 5:41 am
Ohhhhhh OK I read about that tool I was wondering what that was! Ok I'm gonna have to order that tool and try that cuz I guarantee that's what it is.
3kgtaddict213
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Fri Oct 11, 2019 1:27 pm
So they're not those two things in the first picture are they? When I googled camshaft position sensor it showed just the black thing in the second picture that comes out with a single 10mm bolt... Then I noticed the big black circle that the sensor goes into, and I'm wondering if that's what I'm supposed to remove? The whole black circle thing?
3kgtaddict213
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Fri Oct 11, 2019 1:28 pm
Sorry it put the pictures in backwards. So when I said the two things in the first picture I'm talking about the second picture now, the bottom one..
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri Oct 11, 2019 1:51 pm
3kgtaddict213
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Fri Oct 11, 2019 2:07 pm
Ok this is how it looks with those taken off...
3kgtaddict213
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Fri Oct 11, 2019 2:25 pm
Sorry I realize I need to take those 10mm bolts off to see the slots... I'll let you know how it looks after I do
3kgtaddict213
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Fri Oct 11, 2019 2:51 pm
Ok here are how the slots look. I'm pretty sure they are exactly how you were saying they should be.
I used my impact gun on 100psi and it still turned the cams slightly counter clockwise as you can see... I'm pretty sure I could eyeball those back to where they should be right? Kinda makes me nervous though, I was worried this would happen when I took out those 10mm bolts, I'm sure it's a common mistake though right?! I hope there's an easy solution lol
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri Oct 11, 2019 3:15 pm
Look like they are both a little off. (Assuming the front three marks are aligned)
You could use a straight edge. Use the seam to align the straight edge.
Hard part will be keeping the cams in place as you tighten the hub on the other end.
Last edited by RickHaleParker on Fri Oct 11, 2019 3:25 pm, edited 3 times in total.
3kgtaddict213
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Fri Oct 11, 2019 3:17 pm
Marked the center lines with a sharpie and Got em lined up...
Anyway.. Since those were in the correct places, that means I did the timing correctly and didn't mess with my VVT at all? Therefore, I have a stuck valve(s)?
If the timing was right and even if it combusted only once before it lodged itself, the first time I turned the key (maybe I just didn't hear it) there's still no way it could have bent a valve right?
