IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
Can I put the B5254T motor into my XC90 that originally came with a B5254T2?
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
RickHaleParker
Has thanked: 3 times
Been thanked: 361 times
United States of America
RickHaleParker
Re: Can I put the B5254T motor into my XC90 that originally came with a B5254T2?
Post by RickHaleParker » Mon Oct 07, 2019 11:24 am
You installed the starter after the rotation check.
I would have a look at is the starter. It maybe cockeyed and jammed.
Correct bolts in the bell housing, torque converter ... etc?
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
1997 S90, B6304S, AW30-42, Bosch Motronic 4.4 - Sold
3kgtaddict213
Year and Model: 2006 XC90
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Mon Oct 07, 2019 12:09 pm
The starter was the first thing I removed in hopes that I wouldn't have to take the whole motor back out. And the torque converter was never removed from the new motor I just put the old trans right over it, onto the new motor. Never touched the bell housing bolts either. The trans is now off the motor (so it's back to exactly how it was when it was turning over correctly) and the motor is still seized.
The only thing I can think of .. Because of how heavy the trans is, and because I had zero help.. I got it almost all the way into place (there was only about a 5mm gap between the motor and trans) and used the bolts to pull the trans the rest of the way onto the motor (which I KNOW I'm not supposed to do) do you think maybe that center shaft that pokes into the center of the torque converter (possibly unaligned) forced something into the motor in there?
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon Oct 07, 2019 12:32 pm
One thing at a time. Have you removed the serpentine belt?
3kgtaddict213
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Mon Oct 07, 2019 12:38 pm
Yep. Still stuck
Masscomguru
Year and Model: 2008 XC90
Has thanked: 0
Been thanked: 9 times
Masscomguru
Post by Masscomguru » Mon Oct 07, 2019 2:45 pm
most TQ have to be seated to the transmission input shaft first... if you didn't do this, it's probably your issue..
3kgtaddict213
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Mon Oct 07, 2019 2:56 pm
So the torque converter may be locking something up in there? I assumed it went onto the motor first because it bolts up from the timing belt side of the motor, not from the transmission side. The bolts come through the back of it.. Another problem I'll have is, to remove the torque converter now that it's seized going clockwise, I'll have to turn it counter clockwise to get all of those bolts out that I'm talking about..and I've read that that isn't a good idea with these motors because of the VVT
3kgtaddict213
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Mon Oct 07, 2019 4:49 pm
Got the torque converter off and it's still stuck...
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon Oct 07, 2019 6:32 pm
1. Has a Cam pulley slipped on a camshaft?
The three front alignment marks would still be spot on but the cam would be out of sync. Align the three from marks. Pull the Camshaft position sensor and/or covers of the back of the Cams and check Cam alignment.
If that not it:
2. Take the Timing belt and Cam Cover off. Look for stuck valves.
See if it will turn over without the Cam Cover on.
Masscomguru
Has thanked: 0
Masscomguru
Post by Masscomguru » Thu Oct 10, 2019 7:12 pm
any update?
3kgtaddict213
Has thanked: 0
Been thanked: 0
3kgtaddict213
Post by 3kgtaddict213 » Thu Oct 10, 2019 7:24 pm
Oh man I never saw that reply !
So once I pull the camshaft position sensor how would I be able to tell if they're aligned properly or not?
