850 wont start
Turbobrick69
- Year and Model: 1996 volvo 850 turbo
- Has thanked: 1 time
So i just did a timing belt job on my 850, new cap rotor plug wires, turbo rebuild, with a "new" angled down pipe from LKQ junkyard, mind you the 02 sensor is just hangin out, no (sensor bung) the cams are off a bit (half a tooth) as i couldnt get the belt on there with them dead on, all new parts including the timing belt are from IPD, could it be the o2 sensor not getting a reading from the exhaust? Its getting fuel and spark, so i think, i know for a fact its getting spark
- Has thanked: 311 times
- Been thanked: 817 times
O2 sensor will not interfere with startup, it's not that.
Find out for sure about the fuel. Be even more sure the cams are only off half a tooth (which should be OK, I agree).
Is the engine spinning too easily, maybe no compression due to "lawn mower syndrome" ?
Turbobrick69
Thanks, and i found out the prob, it wqs just out of time is all, these engines are really time sensitive is all
- 1209 Views
Last post by whtwgn
- 25 Replies
- 8666 Views
Last post by AmericanT4
- 504 Views
Last post by screwdriver
- 27 Replies
- 3680 Views
- 12 Replies
- 386 Views
Last post by jepe
