IPD sale Volvo Parts
Did you know? 🤔
83 244, Stalls when put into gear
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
thomlep
Year and Model: 83 244 GL
Has thanked: 0
Been thanked: 0
thomlep
Post by thomlep » Tue Jun 11, 2019 6:43 pm
Hello Group,
I have '83 244 GL non-turbo. LH 2.0 Chrysler Ignition. The car stalled on me a few months ago, and knowing the fuel pumps had never been replaced, I replaced both fuel pumps and filter. Now the car will start after some cranking, and run fine at high idle. When I slow the engine to low idle, and put into gear, she will likely stall. I tested the MAF and get good Ohms. I have a new fuel pressure regulator, but not installed yet. Also, engine will not rev-up well. Sudden revving will result in hesitation.
Can ya'll help me with further troubleshooting? I'm going to install that regulator, but are there any other things to look at? I see an adjustable screw on the MAF, what does that do?
Thanks in advance for advice!
-Tom
'83 244 GL
previous '82 240 DL, '98 S70, '95 850
93Regina
Year and Model: 93:240/940
Has thanked: 0
Been thanked: 34 times
93Regina
Re: 83 244, Stalls when put into gear
Post by 93Regina » Wed Jun 12, 2019 7:16 pm
....start after some cranking....
A pinch of starting fluid, directly into a throttle body port, would rule out a fuel pressure issue. If FPR is not holding or maintaining pressure, then hard starts will exist.
I don't recall what LH 2.0 does when AMM is unplugged, but you could do this test and see what happens.
