1996 850R intermittent brake pulsation over bumps
wackenhut
Year and Model: 850R 1996
Post by wackenhut »
I have noticed in the last few days that at least one time per driving, the brake pulsates (seems like abs is kicking in) when going over bumps. This has never occurred before. Does anyone have any idea what could be causing this. There are no codes coming up. Any help is much appreciated.
Thank you.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
My '98 has done that too. How do your brakes perform otherwise? I always associated it with pads that are too hard, and don't seem to grab very well.
Otherwise, it would be a good idea to check your brake fluid to make sure it's at the proper level.
Has thanked: 1610 times
Been thanked: 4068 times
If the wheels are losing traction on a bump, the traction controls (TRACS or STC) uses ABS to control wheel spin - that might be it.
wackenhut
Post by wackenhut »
Just strange that all the sudden this started happening
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
It is more likely for your wheels to lock up when braking on a rough surface, because there is more rolling resistance. I know on my last trip through PA, every braking event set off ABS because the roads are nothing but potholes.
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
start by turning tracks off, also may be the insulation is gone on the pump wires and they are arcing.
wackenhut
Post by wackenhut »
I just noticed now, that the TRACS OFF Light is permanently illuminated. Does this help any in the diagnosis of the issue?
Thank you
bmdubya1198
Nothing changes when you hit the TRACS button? That could be indicative of a failing ABS module, or other ABS/TRACS issues. You can't get flash codes on a '96, right? You probably need Vol-FCR or 850-OBD2 on Android to read ABS codes.
