Engine Mounts Bad?
DRN2001
Year and Model: 2007 XC70
Has thanked: 6 times
Post by DRN2001 »
I read somewhere if the wires on the engine mounts are slack, the mounts are bad. Can anyone concur with this?
I've got some shaking going on under acceleration - new axles, and all new torque mounts, so I suspect the engine mounts, and the wires are slack on both the front and rear... :|
Has thanked: 1611 times
Been thanked: 4072 times
I don’t think this is a valid test. I think the wires are safety wires to keep the engine in place but are fairly slack on new install.
DRN2001
Post by DRN2001 »
Righto, thanks. Any idea how one determines if they're bad? My "shudder" has reduced replacing the torque mounts (they were obviously bad) but it's still there. I wonder also if the motor mounts took a beating by the torque mounts being bad? Another thing: I replaced the upper torque mount, but the two bushings on each side of the cross brace have a fair bit of movement...
