blower motor auto postion not working Topic is solved
Jaumme
- Year and Model: Volvo 850 T5 1993
- Has thanked: 1 time
- Been thanked: 2 times
when i place the blower motor in auto mode the blower motor and the entire climate control components stop working, i have 3 ecc one is dead because the damper motors wont work with this one but the auto in blower motor is working. the other 2 are working perfect but the auto blower is not working i didnt find any information about that, anyone knows something?
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
You could open up the ECC unit and inspect the components inside for damage. Some people have reported damage to the circuit board, capacitors, diodes and other components on the board. While you have it open, you could also test the sliding switch to see if the switch is working correctly when you slide it all the way over to "AUTO" mode.
Have you tried to connect a code reader to the ECC unit to check for error codes? That may provide clues about what is not working correctly. See for example: viewtopic.php?f=1&t=64888
- RickHaleParker
- Been thanked: 977 times
Unit #1: Auto works Dampers do not.
Unit #2 & #3: Dampers works but Auto does not.
Clearly the external circuits are all working. That leaves only two possibilities, you have three defective ECC units or some of them are defective and the others are the incapable reversions of the ECC. There are 10 revisions of the 850 ECC.
The '93 850s used ECC revisions 2 - 5.
Read this thread.
Read this thread.
Active
Past
Past
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The early versions require a ground signal on one of the pins supplied by ignition module or the Motronic ECM if 94 turbo (I don't remember the numbers but I have answered this several times and listed the pins.) and the later are designed to get engine running info from alternator charge light circuit as an engine run signal. The simple fix for the early ones is to cut the wire behind the ECC module and ground it. If you search you should find the earlier replies with pin and wire color info.
- 1543 Views
Last post by jefe
- 1280 Views
Last post by volvomadness
- 16 Replies
- 2335 Views
- 1249 Views
Last post by Ozark Lee
- 2490 Views
Last post by WA-Boater
