Did you know? 🤔
Mother Knows Best - Mag & Aluminum Polish
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 36 times
Been thanked: 76 times
United States of America
MoVolvos
Post by MoVolvos » Tue Jun 18, 2019 11:28 pm
03 S80 T6 - Almost finished de-rattling and putting back all the door panels and center console. Started with repairing the driver's side door actuator motor and replacing the rear passenger door switch. Discovered the 2 panels pretty much came un-glued. The center console locking mechanism was not working and pops out easily so decided to remove the entire unit to see what was going on also.
The previous owner(s) used excessive quantities of Armour All or similar so the door panel are all afflicted with the sticky dash syndrome. Tried the following using a tooth brush, large bristle brush and green scouring pad to no avail.
1) Super Clean: Did not removed the stickiness but left the panel all white and dulled the Faux Walnut Trim. Melted really.
2) 91% Alcohol: Same as Super Clean and melts/dulls certain soft plastics easily.
3) Magic Eraser: Left panels whitish but if you rub hard enough the surface will be cleaner then both 1) & 2) but at that point the Eraser disintegrates.
4) Various Other Cleaners: Goof Off, Laundry Detergent...
Everything seems to either dried out / perhaps even removed a layer of the panel material while embedding the dirt and spreading the stickiness. Tried a wax cleaner polish and nothing still but saw Mother Mag & Aluminum Polish on the shelf next to it.
http://www.mothers.com/02_products/0510 ... slider1=21
Well, it looks like Mothers Knows Best after all.
It removed the black grease (old Armour All / body oils / grease), kept the surface from drying while removing the sticky stuff. Still requires a good of amount of rubbing with a towel however. Will try it with the tooth brush and green scouring pad tomorrow.
Mothers has turned out to be a great multipurpose go to chemical for headlights to windshield and some have used it to polish the dash plastic. If you get stuck removing whatever, give Mothers a try.
Side Show
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
