Hi,
The inside door handle on the passenger side does not do anything when pulled. No noise and the door does not open.
How hard is it to fix the linkage on these things, or could it be worse? v70 1998
Thanks.
Door Handle Does Nothing
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- Has thanked: 311 times
- Been thanked: 817 times
If the outside handle works fine, I would expect it to be a simple fix. If the linkage has fallen off then reconnect it, if the cable has broken then replace the inside-handle-and-cable assembly (junkyard trip there). Those are my two guesses.
I'd get on it soon, as you don't if the other handle stops working then things get much more difficult to fix simply because you can't get the door open to remove the panel. When you do pop off the panel to actually figure out what is wrong, you may want to buy a couple new plastic snap connectors. The 20 year old ones tend to break easily.
- Has thanked: 2854 times
- Been thanked: 1332 times
This. I helped my buddy fix his P2 S60 with the same symptoms, simple quick reconnect fix.erikv11 wrote: 19 Jun 2019, 09:41 If the outside handle works fine, I would expect it to be a simple fix. If the linkage has fallen off then reconnect it.
- Been thanked: 4063 times
Just another reason sunroofs are great
- MrAl
Hi,
Oh thanks to you all for the suggestions, especially about the fact that if the outside goes bad too im screwed.
The sunroof idea also sounds good, if i had one. Another way out.
You know what blows? I found out when a very significant lady friend tried to open the door. I was embarrassed to no end. I had to open the window so she could reach out and use the outside handle if needed. Of course i open the door for her anyway but i hated that she had to experience that.
Ouch. That could end a first date pretty quickly.
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
This is a great way to screen potential partners ... if she doesn't appreciate your quirky old Volvo that sometimes needs a little love, let her goMrAl wrote: 20 Jun 2019, 03:49 You know what blows? I found out when a very significant lady friend tried to open the door. I was embarrassed to no end. I had to open the window so she could reach out and use the outside handle if needed. Of course i open the door for her anyway but i hated that she had to experience that.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
My test would be if my date could yoga through the sunroof!
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Nah, hand her gloves and invite her to a good game of alternator tetris =)
- MrAl
Ha ha.
It's strange that i did not experience the problem before that.
I have had other passengers before that.
