When it rains it pours
markopolo
Year and Model: 2006 XC70
Post by markopolo »
Hi Newbie here
OK so I have a 2006 Volvo XC70. Vehicle has about 225K miles. Treated well. OK so about a month and half ago started having problem where starter would not engage when key turned to start position. I believe I have diagnosed this to be the corroded wire clip to the starter as identified by another person. This problem has not been fixed yet but will be shortly
OK onto the new problem that just started. When I turn the key to the aux position (and this seems only to be when raining or very humid) the DIM becomes erratic with spedo and RMP gauage moving and just about every message indicator going on and off. When I try to start the engine turns but does not start. I have a video but not sure how to load it.
Any thoughts and help appreciated.
Many thanks
Mark
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Hello
For the weirdo gauges, use a voltmeter and test the alternator and the battery. At idle it should look 13.5v-14.5v (depending whether the battery is being charged or is already fully charged)
markopolo
Post by markopolo »
Will do. Also if I have a faulty coil pack could that be a cuase of the issue as weeel?
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
markopolo wrote: 19 Jun 2019, 12:08 ... starter would not engage when key turned to start position. I believe I have diagnosed this to be the corroded wire clip to the starter as identified by another person....
Many thanks
Mark
Does the starter motor spin, but not engage with the flywheel?
Or does the starter motor not spin at all when called upon?
The way you worded it, it could be misconstrued 1-2 different ways.
Our 06 recently did something similar to what you're describing, about it cranking but not firing. I replied to somebody else's post in regards to it a few months back. Here's what I posted. By the way, that red blurry thing in the picture is the pull for the oil dipstick.
viewtopic.php?f=9&t=87155&p=486462#p486462
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Has thanked: 1609 times
Been thanked: 4065 times
markopolo wrote: 19 Jun 2019, 17:31 Will do. Also if I have a faulty coil pack could that be a cuase of the issue as weeel?
No, a coil pack won’t impact the cranking part of the starter nor the instrument cluster.
