Did you know? 🤔
2005 XC 90 4.4 V8 non turbo auto Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
nisan17
Year and Model: 92 940 turbo
Has thanked: 2 times
Been thanked: 0
United States of America
nisan17
Post by nisan17 » Thu Jun 20, 2019 1:20 pm
Question(s) regarding 2005 XC90 V8 4.4 Yamaha with auto trans and no turbo. My daughter is looking at buying this model with 82k on the odo. What should she be concerned about? It has nothing wrong that we've been told or could see. Doesn't use oil, fluids, hoses and belts are good. Oh the oil level light goes on every now and then, but a supposed mechanic says bad sensor and shouldn't be alarmed. Thanks for any input.
Kevin
Masscomguru
Year and Model: 2008 XC90
Has thanked: 0
Been thanked: 12 times
Masscomguru
Re: 2005 XC 90 4.4 V8 non turbo auto  Topic is solved
Post by Masscomguru » Thu Jun 20, 2019 4:59 pm
That particular model year has a particularly nasty issue with the center balancing shaft. The bearings let go. It’s reparable if you catch it, but if not it will destroy the engine. It’s also a complete tear down to replace. The mileage varies on failure greatly. Some never do some less than 100k some later in life. Aside from that they all need valve cover replacements at some point.
That being said, the oil thing is ok. They light up with only 1/2qt low and on a 7500 mile OCI that’s not too bad.
If you are looking for these in that year range I would recommend the 2.5 over the T6 or V8.
jimmy57
Has thanked: 4 times
Been thanked: 258 times
jimmy57
Post by jimmy57 » Thu Jun 20, 2019 5:23 pm
The balance shaft bearing issue is a big deal and worth an inspection by someone familiar with Volvo V8s. The problem has a remedy by removing upper intake and drilling the drain hole that 2006 and later have with a long drill bit. It is not a big job but the drilling only goes 1/4 inch to go into an area where any water can drain. Water is not usually going to be there but if the engine gets washed it is a risk.
These users thanked the author jimmy57 for the post:
nisan17
Roger_850T
Year and Model: 854T 1995
Has thanked: 0
Been thanked: 15 times
Roger_850T
Post by Roger_850T » Fri Jun 21, 2019 4:20 pm
I have the same XC90 - I agree with the other posters - the issue with the balance shaft bearing is due to washing the engine, or in my case, I think I got some fuel in there when I changed the fuel pressure sender. To fix it, you have to remove the intake manifold and one of the cylinder heads. That said, it still runs nicely, and that's the only major issue with the engine. It's got a timing chain, so no belt to replace. From numerous discussions, fuel economy seems to be about the same no matter which engine you have, so it's really a function of it being a big, heavy vehicle. I get 17mpg pretty consistently. (The people in England with the diesel engines always post ridiculous mpg, but it's diesel, and they're measuring in imperial gallons...)
Also, I find my oil level sensor is fussy about what kind of oil I put in. Specifically it does not like Castrol Magnatec, and will give me erroneous low oil readings all the time. It took me changing out a $100 sensor and no change to figure that one out.
Roger
These users thanked the author Roger_850T for the post:
nisan17
'05 XC90 V8 140k
'95 854T 310k
'02 V70 159k
'03 S80 111k (crashed)
'93 945T 217k (gone to be parted out)
'87 245 300k+ sold, still going
'84 264 Diesel, RIP at 160k
'78 242 manual everything.
'73 P1800ES, fun until the rust set in...
