I was expecting to find it under the metal cover, but is not there...
I'm attaching the picture of what is under the metal cover, and don't see a way to get below that?
2005 2.4 S60
Need help replacing the Fuel level sensor (Driver side)
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
So..2005 S60 2.4..the fuel level sensor...the float...is built in to the fuel pump. You have to figure out if you have a plastic gas tank or a steel one. You'll also have to find which chassis number you have... which usually means.. early 2005 or later 2005. The VIN number on the dashboard has all the data you'll need to order any parts...ok? By the way... check the other side
titodj
- Year and Model: 04 XC90
- Has thanked: 3 times
Thank you!
So according to the VIN, the pump that I should use has a level sensor, but also has a long cable that I guess goes connected at the other side of the tank to the sender unit, that also has a level sensor. and I don't know how to reach.
This is the VIN, in case it helps. yv1rs612752447242
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
its under the back seat on the other side, youll could need a removal tool if its like the xc70
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
My level sensor was also very random so I pulled it and cleaned the potentiometer contacts and - perhaps even better - also compressed a little bit the "U" portion of the float metal rod, because when it was sitting on top of the potentiometer it had a little bit of side-play, which may be the reason the gauge was getting stuck. Since that video - sorry about the video quality, not the best - the level gauge is very accurate and I have no problem trusting it. At the end of the video I put a link how to access to the sensor, however that was on my car which has the metal tank - on plastic gas tank cars it's a different access hole and locking ring that requires a special tool sold on Ebay
- oragex
I don't know about the specific configuration on your car but you can see here after about 5:00 there are two covers under the rear seats - one is hidden under the upper section of the seat and difficult to access (need to remove the upper seat). The picture in your first post seems to be just a hole for other gas tank configurations - that cable is actually an ABS cable
titodj
Thank you, that's the configuration that I have, behind the back of the passenger side it's the fuel pump, and the sender is supposed to be under the seat on the drivers side, but I can't find a way to reach it.oragex wrote: 23 Jun 2019, 13:24 I don't know about the specific configuration on your car but you can see here after about 5:00 there are two covers under the rear seats - one is hidden under the upper section of the seat and difficult to access (need to remove the upper seat).
- oragex
Is it possible the sender assy is secured to the pump unit itself ? That's how it was on my model year (and a bit tricky to remove, had to separate them inside the tank)
- 48814 Views
Last post by ggleavitt
- 3427 Views
Last post by Durenol
- 2203 Views
Last post by kdaide
- 932 Views
Last post by sleddriver
- 14 Replies
- 12439 Views
Last post by pgill
